Need a Camber kit and need to know which is the best one to buy.
200,000 mile club
So I have a 2005 TL 6speed with H&R Sport springs and Koni Yellows (bottom perch in front/middle perch in back). I had the car aligned about a week after the install and the guy said as expected that the test showed the car was in the red. So I decided to give it a whirl on the new tires to see how it went and that was a mistake.
Started to notice some noise during the highway and when I rotated the tires over the weekend, I noticed the inside edge was wearing more than any other part of the tire.
Should I get a camber kit front and rear? I really don't want to have any issues with another set of tires. I learned to bite the bullet before you need to spend extra money on tires. Please let me know what kits are the best to get. Thanks guys.
TYPE-S CBP MT
I say get the camber kit, you'll be happy in the long run!!!
I bought a set of Ingells that I will install with my tein SS.
I think stillhere153 has a set for sale in the black market....check and see if he still has them.
If your camber is off, tires still shouldnt wear that fast!!
btw, I thought Al's camber kit was a front camber kit, IDK though.
You sure they fixed your toe? Cuz thats what really screws up tread
200,000 mile club
You say that but I drive all highway miles and have 20k on these tires already so yeah I would see wear at this time. I already realized (a little too late) that I need a camber kit. That is not the question. I need to know from guys with the camber kit, if they like it and where they got it from.
I saw Stillhere153 had his for sale but I am gonna get a front and rear so I might as well get it from Excellerate or Heeltoe. I haven't heard back from them on pricing and availability.
200,000 mile club
Thanks guys....Yes I have delt with him before and he has delivered on a good product in the past. Just waiting for pricing on the kit. Thanks for the pricing info.
My bad, didnt know you had 20K after the drop
200,000 mile club
No worries man. Not everyone drives the car as much as I do. I am seeing the camber kit is a must for the rear, just not sure about the front. I see that it really doesn't hurt to have it on all 4 corners.
Byruns
Might wanna read ^^^... according to Marcus, it's the other way around. I myself also found it to be true that the front tires wear out A WHOLE lot faster than the rear. The rear tires practically were in great condition compared to the front tires after i rotated them.
OMGWTF4THGENTL
Originally Posted by Byruns
https://acurazine.com/forums/showthread.php?t=147290
Tires look great. No measurable uneven wear. You don't need a camber kit... ever. I'm convinced.
Sounds like you got a toe problem.
200,000 mile club
I guess I will go to the alignment shop tomorrow and see if they come up with anything. It just sucks when you can't do this process yourself. You have no choice but to take the shops word that the car checked out and they adjusted everything. I will see what they say and let you guys know. Thanks.
Byruns
Originally Posted by Kennedy
True dat.. I have 15K on my Volks/Falkens... 1.5+ inches on Tein SS. Rear camber is -2.1...
In your case, i don't think your camber wear will be anywhere near where mine is. I suggest you just get a front camber kit and call it a day.
Camber kits are needed on an individual basis. A certain degree of negative camber can be good/without problem or desired for racing. However if you have too much difference in camber between front and rear, the car maybe squirmy at certain speeds and conditions. The rear camber kit on 3G TL will allow you to dial it in pretty good, to match the front, if even needed at all.
If your dropped around 2" or more, I would at least consider if its worth it.
I got a Comptech rear camber kit.
150 bucks for the kit at a local tuner shop.
I wasn't too concerned with tire wear, I just didn't like the look of the rear wheels not being straight. I had the camber kit installed at the same time the Eibach springs were put in. About a week and a half later I had the alignment done, and the camber adjusted back to factory specs. It looks really good... but it's all personal taste. Some guys like a bit of negative camber... I don't.
Jimmy
Jimmy
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
