mounted & balanced...
just a quick question...if the site says the wheels come mounted and balanced...does that mean all i have to do is take my old wheels off and put my new wheels on?? do i have to do anything else???
under normal circumstances, yes all you have to do is remove your old wheel/tire & put on the new set. some wheels require a spacer if the hub & wheel don't match up perfectly. that'll be visible upon installing the wheel, or if you get a vibration at freeway speeds.
'01 TL Taffeta White
18x8 Blitz Z2 Technospeed
Pirelli P7000SS 225/40/18
H&R SportSprings
Polarg M-12 Corners
Solaris High Beams
H&R SportSprings
Polarg M-12 Corners
Solaris High Beams
Guest
Posts: n/a
Guest
Posts: n/a
dc121,
I put in a new set myself and using those spacers you talked about. These are the big plastic rings right. I can't see any different with or without those spacers when I changing the wheels, so I put them in. But my steering wheel has a little vibration from around 75mph to 85mph. Also, my steering feels kinda light. I use the new Yokohama Parada tires. Do you know why? Should I take those spacer out. What do you think I need to do to solve the vibrations?
The technician where I bought the package from told me that the vibration doesn't damage anything on the car. To make the vibration go away, I need to rebalanced my wheels by putting weights on outside of the wheels, which won't look good. They also told me that they only balanced the wheels up to 70 mph.
Thanks in advance.
Thanks in advance.
Originally posted by blee828:
dc121,
Thanks in advance.
dc121,
Thanks in advance.
'02 Nighthawk TL-S
Comptech Springs / Comptech Headers
Alpine CVA-1005 Head Unit / Alpine CDA-7863 CD Player / Alpine G320 EQ / Alpine DVA-5205 DVD / Alpine NVE-N851A Navi / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by Alpine MRV-1002 amp / Dual 10" JL Audio W-6 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers / 20% Tint all-around
__________________
'00 Nighthawk TL
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Cross-Drilled Rotors / Pirelli SP7000 Tires / 35% Tint all-around
Pics of my TL and Fun/Crazy Pics
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
