Megan coilover issue -_-
so i took my 05 tl to a shop few miles away to install my coilovers, the dude installed my coilovers and everything seemed fine until 5 days after the fronts were knocking really hard, i searched acurazine and found out about that 17mm nut that loosens up at the top right under the dampening knob..i took off my struts and tightened them up reallll tight...next day, the rears start knocking..i took off my rear seats and the right side nut was pretty tight and the left side was loose..so i try tightening it but it doesn't seem to stop moving...as if the nut was shaved...and doesn't completetly tighten and it just keeps moving when i try tightening it..i also noticed the right side started to slowly loosen up as i drove...can anybody identify this issue and how i can stop the nuts from loosening up? do i have to take the coilovers out and adjust something... this is really frustrating me -_-! thanks for ur help
Iv had the issue up front.. bascially you just tighten the nut... you cant get it to tighten all the way because it keeps spinning.. i havent had a issue so far... you should contact megan if it keeps get loosened
1fatcrxnem1
22
06-01-2018 01:23 AM
WDPanda
10-04-2017 05:43 PM
mugen_kid
11-13-2015 10:38 PM
