Matched 2004 A-Spec wheel paint?
Has anyone successfully matched the 2004 A-Spec wheel's paint color? I scuffed my rims the other day (AGAIN) and since it's very minor this time I'm thinking of fixing it myself witih some patience, sandpaper, and bondo. However, I have no idea how I'd match the paint, so if you have any suggestions please help
I am in the same boat, I just got some used a spec wheels, need to touch them up before i put them on.
A web site I found has the wheels listed as Anthrecite not gunmetal.........so would the OEM anthrecite color match? I can probably get the OEM paint in a can from duplicolor.
08703-nh623mah
Originally Posted by ITL
Why start a new thread....search instead
08703-nh623mah
08703-nh623mah
Originally Posted by DeadLock
and if you have read the entire thread, you would know that we are looking to match the OEM gunmetal a spec wheels not the silver ones
Thanks RJS
have you used it before? I am planning on patching up the wheels myself, is it a spray can?
Do you know what cars came in that color?
I will need it for more than chips.......I was going to use a spray can.
I need to use some putty, than sand it smooth, than primer it than recoat those parts of the wheels.
for those who also want to try it, that is a GM 1995 paint code if you are searching duplicolors web site
I found some of it here.........
link to buy it
link to buy it
Nice job, guys! When the weather is consistently nice I will give this a shot. I just washed my car yesterday (after about 5 months of not washing it) and boy, it looks nice!
hey RJ, do you have any pics? if it matches real well, I will give it a try, but I dont know how well it will match, plus I would have to clear the entire wheel probably
anyone know a repair shop in NYC lol........I need 2 wheels fixed, the others are good
Originally Posted by willz822
Too bad the original poster didn't specify that he had gunmetal rims. Only you were asking about the gunmetal aspec wheels.
Everyone,
My apologies for the misunderstanding. I should have clarified that these were for the gunmetal colored rims. I shouldn't have assumed that everyone knew the 2004 A-Spec rims only came in one color! My apologies!
Update:
I just got the GM435 2 in 1 scratch fit kit ($7 bucks locally I know rip off)
They didn't have the spray can, but I thought I might as well try it and see if it matches before I buy the can online.............
I was surprised at how well it matches the wheels.........its as good as touch up paint you would expect from Acura........blends pretty well with the OEM A spec gunmetal look, and is perfect for the small scratches..........I will take some before and after shots.......
I have 2 wheels to fix up, I think I am going to just "touch" them up and see if they look ok, I dont expect them to be perfect looking, as long as the scratches don't hit your eyes when they are installed I am happy.
Originally Posted by SpecialFX
The only problem with using Acura touch up paint is that they don't sell it in spray cans (to my knowledge). Has anyone found a matching aftermarket paint?
check here where I bought some for my son's NBP Civic....
click here
I think the GM435 is a very reasonable match. However, I think if you are going to spray it on the results may be a bit different than the touch up. The paint on the Gunmetal looks to me to have a clear coat. The touch up does a good job matching the scratches but in broad applications the one part touch up may look very different than the somewhat flatter gunmetal grey with clear coat.
But if I were to refinish them, after sanding out the rough parts, I would prime the entire wheel, paint the entire wheel, and clear the entire wheels.........this way you can not see the diff in the shades...........
I just touched up the wheels, they were real bad before, they are not as bad now, nothing close to perfect, but enough or me to be ok with it. Regardless I will get some curbs on them anyways, being as they are 8.5" wide and only have a 235 wide tire...............
Next tires I get will deff be 255 wide, and at that point I might fork out the money to get the wheels refinished professionally.
i actually started a thread on this last week or so, no dice either. however in this thread https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/painted-wheels-please-come-706716/
Powerflow painted his wheels and it seems to me that it's close to the a specs, i could be wrong as i haven't done a true side by side compare but it looks really good. and done with high quality. I was going to head to the dealer tomorrow and see if they know anything but it seems that someone from this thread already tried. I will see what i come up with and follow up tomorrow. hope this helps you out
nanos
11-12-2015 08:41 PM
merc009
10-03-2015 12:59 AM
nuldabz
09-03-2015 05:49 PM
