Lowest Setting on Tein SA with no Rubbing and no Fender Rolling?
Old 12-18-2013 | 12:12 PM
Kaiii's Avatar
Wow Amaze Such TL-S
Thumbs up Lowest Setting on Tein SA with no Rubbing and no Fender Rolling?
Hey guys,
Could anyone with the Tein SA give me an idea of how low you can go on them without rubbing (assuming no rolling of fenders)? I'm looking for the measurement in terms of the amount of space on the coilover. I'm currently at about 1 and 1/8 inch on the front and back
Thanks!
Old 12-18-2013 | 01:02 PM
Noober's Avatar
rub on what? what is your wheel set up?
Old 12-18-2013 | 01:17 PM
Undying Dreams's Avatar
Slam it until it rubs!
sockr1's Avatar
There's no cookie cutter response. It depends on your specific setup. Your tires, your wheels, your camber, the streets you drive on, and even then each car will respond differently. You just need to lower then drive it around. If no rubbing then lower more and drive around. Keep repeating til you find your sweet spot. It's tedious but that's the only way you'll know. Then get an alignment to set toe to 0
The following 2 users liked this post by sockr1:
Kaiii (12-19-2013), Midnight Mystery (10-30-2021)
Old 12-18-2013 | 01:29 PM
Kaiii's Avatar
Wow Amaze Such TL-S
I just have 17" stock type-s waffles with michelin pilot super sports (235?). I haven't gotten the alignment yet and will try to get toe as close to 0 as possible.
I think I'm most worried about rubbing on fenders
Edit: Hi sockr! I haven't been able to do the navi hack yet haha...i get stuck in the cmd prompt ~_~
Old 12-18-2013 | 02:07 PM
Kaiii's Avatar
Wow Amaze Such TL-S
btw thanks guys for helping me out with this. it goes without saying but i know absolutely NOTHING about suspension settings, wheels and the like.
Old 12-18-2013 | 02:15 PM
Noober's Avatar
stock wheels. you can max them bitches out. slam it to the ground it you like.
Kaiii (12-19-2013)
Old 12-18-2013 | 02:17 PM
We all have to start somewhere.
I am on Tein SA, my wheels are 18x9 +30 and I think I got to around 2" before it started rubbing. Once that started I got my fenders rolled by a good friend and went even lower
Rolling is scary at first but get someone who knows what they're doing (NO baseball bats or broom sticks! ) and you'll be set
Kaiii (12-19-2013)
Old 12-18-2013 | 02:31 PM
sockr1's Avatar
stock wheels as low as you want, they are pretty sunken in
Old 12-18-2013 | 02:35 PM
Kaiii's Avatar
Wow Amaze Such TL-S
Maybe I shouldn't worry about it then haha. Only problem is that some of the roads around my area SUCK. Also, if I ever have to go up to San Francisco, it'll be a nightmare. (I hate that place..)
Yeah, I just saw your thread (here), you're on 18's but it looks like the rears got lowered more than the fronts did since you maxed them out. I don't think I'll be able to max it out, but do you remember how much "space" on the coilover (the black portion with the rivets) you left before it started to rub? Unfortunately I didn't measure the distance from the fender to the ground when it was stock or anything like that, so I don't have a good way of measuring it other than how much space I'm leaving on the actual coilovers.
But if I add spacers I'll be doomed
Old 12-18-2013 | 02:46 PM
I have no idea. Maybe a tad less than an 1" on the front and .5" on the rear.
I'm sitting pretty even at the moment.
Kaiii (12-19-2013)
Old 12-18-2013 | 03:44 PM
Kaiii's Avatar
Wow Amaze Such TL-S
cool thx austin, i'll use that as a guideline for the absolute bottom of my options. i'll try to mess around with it when i can..
Old 12-18-2013 | 04:56 PM
I hate cars's Avatar
I have 255s on stock rims and you can't make them rub. No matter how much weight is in the car, how hard you corner, how bad the roads are, it can't rub. It hits the bumpstops before it can rub. Mine is about 1.5" lower than stock.
Kaiii (12-19-2013)
Old 12-20-2013 | 04:05 PM
Kaiii's Avatar
Wow Amaze Such TL-S
Adjusted to ~1" space left on the coils on the front and ~0.9" on the back and it looks excellent. Got an alignment today (though maybe I should've held off for a bit).
After the alignment, I ended up with negligible camber on the front, but they were only able to get the rears down to around ~2.6 negative camber on the back. I THINK I don't need a camber kit but any suggestions would be welcome.
Also a dumb question for anyone who reads this - but if I added 10mm wheel spacers would I be in danger of rubbing or is 10mm somewhat negligible? Also would I need to get an alignment again?
Old 01-21-2014 | 03:55 PM
10mm spacer should be fine. You're on stockies, right?
Most people even go with 15 front and 20 rear.
And with -2.6 camber you shouldn't have any problems.
nanos
11-12-2015 08:41 PM
V-tecAc
09-21-2015 09:25 AM
DunesCreations
09-09-2015 12:03 PM
braveheart
09-07-2015 08:12 AM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Lowest Setting on Tein SA with no Rubbing and no Fender Rolling?
