Low tire pressure warning error
Anyone have this happen? It says my right front tire is low on pressure, but when checking the pressure, they are all about the same ...FL 30, FR 30, RL 31, RR 31. It went away once, but once I started the car up again it showed up again, without any drastic drop in pressure.
What could be the problem?
1 Post
Did you check the temps cold or hot? Actually, I think you are a bit low. I would do what's suggested and air the tires up to specs. (A MT is different that an AT) See if that doesn't take care of the problem.
Registered but harmless
Received 1,149 Likes
Tire pressures do make a difference
Originally Posted by aznbo187
So 32-34? Is 1 or 2 psi really that much of a difference?
You can adjust the tire pressure to what you think feels best. I do not recommend using less than recommended pressures or more than 40 psi. Do the tire pressure check when the tires are cold (parked 6-8 hours in shaded area)-- as you noted, the air will heat up when tires are exposed to the sun, and the tire air will continue to heat up while driven.
Originally Posted by Will Y.
You will likely extend your tire life with the recommended 35 front/32 rear psi on your 6MT (check your driver's door sticker, which has the recommended pressures). The car will also feel a little firmer and gas mileage might improve. The different front v. rear pressures are to reduce the understeer ("push") you probably feel now with equal tire pressures. Your car will feel more neutral and responsive at recommended pressures or slightly higher.
1fatcrxnem1
22
06-01-2018 01:23 AM
TLDude876
12-28-2016 03:18 PM
HeloDown
09-08-2015 06:51 PM
