Loose Rear Strut! WTF?
#41
Originally Posted by PeterUbers
This is a bit disconcerting since I have the CT RSB on order.... hopefully I can lube it up enough to avoid most of the clunking ..
is there anyone out there w/ the CT RSB that has NO clunking?
No clunking here. I had the clanging noise once only because I didn't torque the end link nuts tight enough. Once they were retightened, all was well. I do need to lube up the bushings with marine grease though as mine are moaning and groaning going over speedbumps lately. Other than that, they have been trouble free.
dsc888
#42
Team Nighthawk MechE
Originally Posted by ANTHONY741
What is the CT RSB- I have original car (04 TL)- no mods and have thisn issue
I've got one AND the issue... Still investigating the clunk.
#44
DSC --
did you ever resolve that clunk you had w/ the front coilovers? And have you done your rear coilovers yet?
dsc888
#45
My Situation Update
The dealer replaced my passenger rear strut and the thump is gone--they also replaced my upper storage tray due to the fact it rattled like crazy in the cold weather
#47
Will be installing the CT RSB today -- will post pics and will discuss any clunks if they arise.
Anthony: Could you see anything wrong with the strut??? Was it leaking or anything like that?
#48
dsc888
#50
DSC .. I can't wait. Where can I buy the grease? Is it easy to re-lube bushings?
And yes, greasing and regreasing is a piece of cake. You simply remove the brakets that hold the bushings in place, remove the bushings, recoat the bushings and reinstall. It's a 5 minute job. Shuts up all the moaning that occurs due to the harder rubber bushings that Comptech provides. Bushings have to be harder to be more effective at controlling body roll. But the side effect is icreased noise. Good luck.
dsc888
#52
My 2002 TL with CompTech sway bars has the occasional "clunk" on bumpy roads, speed bumps, but not much on turns. Interestingly, when its wet, it doesn't seem to make the noise. I got under there and "re-mounted" the rear sway and greased it myself about 5 times over 3 months and adjusted the clips, but it didn't seem to always "fix" the clunk noise. When I first installed the CompTech bars, it was the front that slid from side to side on turns which made a click or knocking noise when the bar clips hit the mounting brackets. But after adjusting and tightening the plastic limit clips many times, I got the fronts to settle down and be quiet. But the current noise appears to be in the read. Adjusting the clips tension or location and greasing the mount brackets does seem to solve the "clunk" noise.
So I had suspension experts check out the rear suspension and bounce the car, back up and stop, and then lift the whole rear end and pry one wheel up at a time. They found that the left rear shock had about 1" of play in it, where it could easily be lifted and dropped without offering much "shock" resistance. The recommendation was to change shocks. But they also tweaked the rear bar (not sure what they moved), and it cleared up the noise for a couple of weeks and it doesn't clunk as much. I haven't changed shocks yet, but am planning to soon.
My right rear swar bar mounting bracket was really bent forward like a Y split tear in the metal. I assumed it was from my hard driving, and it may have given out on one of my fast freeway exit left turns, where I almost lost it. A couple days after I noticed the bent bracket, the 6" link to it broke off completely perhaps from all this jacking up and down. I wondered if those short 6" plastic ball links are part of the noise problem. I heard there is a service bulletin on the links breaking, but have not found it.
I'm still trying to chase down the occasional clunk noise on bumps. I don't think its the CompTech bars anymore. It may be a bad rear shock, but this will cost about $1K to upgrade them all before I find out. It anyone knows more, let me know.
#53
I finally took my car to the dealer for the 2nd time to fix this “clap” noise from the rear suspension. I already had my toe replaced because of the noise. After that fix I got my RSB installed. The sound only happens when going over a bump or holes. They said it was normal so I took the demo car for a spin. Surprise!! No clapping noise from that one.
I had the same noise before I installed my Comptech swaybar, and I still have the noise now. The tech is trying to pin point at the fact that it maybe my aftermarket swaybar making this noise.
Try this at home. Go over speed bump going 5 mpg. The back side will make this noise.
#54
Overlord - Team Abyss
I have the comptech RSB and A-spec suspension. I do not and did not have these sounds that are being described in the thread. I go over speed bumps at least 6 times a day on days that I work. Wish I could point you in some direction but I can't. Are you sure it isn't something in the rear deck? Maybe the spare tire area ( I know someone took that out - was it you?).
#55
I *think* PeterUbers found the culprit and posted in another thread. I think it was the middle rear seat belt tensioner and involved removing the rear seat to fix. As long as it isn't anything "bad" I'll live with the noise cause there aint no way I'm taking all that time to take out the back seat!!!
Let your dealer know about that and see what he says. I'll see if I can find the thread and link to it here soon.
#56
Originally Posted by DarkWraith33
I got it... 100%... Same exact thing. It is NOT the RSB.
But my noise is from out side, right side, rear suspension.
what is culprit?
Is the middle rear seat belt tensioner noise be inside?
#57
Oh my noise SOUNDS like that too, as did PeterUbers from what I can recall... Remember you're driving and being 100% sure where that sound comes from isn't... Well... 100%... Lemme find that thread...
#58
what is culprit?
what is culprit?
https://acurazine.com/forums/ramblings-12/word-origin-110412/
THOUGHTS???
#59
Oderint dum metuant.
FOUND IT... Read this my friend....
https://acurazine.com/forums/showthread.php?t=110412
THOUGHTS???
THOUGHTS???
#60
Thanks DarkWraith33 for the link. You are cool guy!
I just called the dealer and they are ordering new shocks. I think right rear suspension is being worked on. I would like to ask the tech to do this fix from the link, but they are going to say the sound is coming from the outside so they prob. will not do it.
I am not concern because 3 shocks will be old and 1 will be new. I think one side will be higher and wear out my tires unevenly. I only have 4200 miles so maybe I shouldn’t worry too much.
I’ll keep you guys updated. =)
#61
Well folks, pursuant to my pics above. I've done a little more digging into this noise. I took everything outta the trunk: spare, trunk tray, etc... Anything I could get out is out. Noise remained (which I suspected)...
A telling occurence of the thud occured while I was testing in the above conditions. I made a turn over a small bump, such that my rear suspension was tweaked, i.e. right rear up more than left rear due to the bump. After coming off the bump (not during), about 1 second later I got the thud while basically on straight and level ground. Clear as day.
Went to my friends where we jacked her up and looked at everything. Nothing is loose, nothing has marks to suggest something making contact... No missing dirt, no nicks, etc... The ONLY thing with tell-tale marks of movement is the Comptech rear sway bar (as seen above.) I am almost convinced... DAMN NEAR 100%. That this thud/clank is somehow coming from the sway bar and its side to side movement during driving.
As I lubed and greased the bushings during the install and the directions did not call for that, we dropped the bushings and cleaned them good. NO MORE LUBE at all, and reassembled. I read above someone else with the clunk had also lubed? (Coincidence?? I'm all for other ideas at this point) I only got 5 miles on the car after the de-lubing, but I didn't hear the noise... Further driving will tell the tale.
Final observations as of now: I am almost sure the sound is related to the Comptech RSB. There is nothing else it could be. Sounds occurs at low speed over small bumps sometimes, where my suspension is only in a very small amount of travel so nothing is hitting/bottoming, etc.
I don't believe anything is being harmed in this manner. It is simply the RSB moving left/right as seen above. I never noticed with stock bar, but I never drove sans radio. I am tempted to throw the old rsb on and see if sound goes away.
Ubers.. Perhaps you are this adventurous??? I'll bet you a beer if you remove the RSB and replace with stock the sound goes away!
Questions: Anyone got the thud/clank and NOT have the comptech RSB??? Anyone got the thud/clank and NOT lube your RSB install?
THOUGHTS people?
THOUGHTS people?
I had this noise before I got my RSB.
#65
has anyone tried a thin foam or even dynamte on the rear struts at the top where they mount to the car, b/c think of this the two bolts that hold it at the top the metal plate that is holding the spring in place rest under the metal body of the car, when you hit bumps it makes the noise.
1)you could make sure the top 2 strut nuts are tight
2)or you could put a thin layer of a sound deadining material b/n them and this may help
#66
2004 w/ comptech rsb and thunking from rear. i did the 5 page tsb repairs myself...
i did notice the frquency seems to increase as the fuel tank gets empty. perhaps it's the attitude change as the suspension becomes unloaded?
i'll re-lube and see what happens-
#67
CEO, Team Anthracite
Mine was making the same clunking noises but after the dealer cleaned off the lubricant on the RSB, it stopped making the noises. The struts were fine.
#68
Dr. Feelgood
Mine happens only on the rear passanger side when I go over a bump. The sound came up after the dealer replaced my strut on that side. It is a little higher than the other side. Probably because it's new?
#70
Yes!
I had this same problem, but I never brought it in. My friend wrecked my car this past weekend and I brought it in and I asked the tech about the problem; and supposely, there are a lot of people out there w/this issue.
#71
i had this problem also, i took some dynmat which is used for rattles from car stereo and cut it out for the top of the rear struts, i then reinstalled them and this fixed my noise/rattle/clunking 100%
#72
so after reading all that, are dealers covering this "mysterious" thud/clunk under warranty? I am having the same problem, and have the CSB installed. I'm trying to weigh my options here as to what I should do.
#73
I'll have to try your fix when this frigid Boston weather passes. I too have the CT RSB with the A-spec suspension. I noticed some pretty awful clunking over over potholes or bumps. Funny thing is that if BOTH wheels went over a speed bump, there is NO clunk. But if one side went over, you get the clunk. I guessed swaybar right away. My original theory was that the rubber bushings had shrunk as the weather got colder and no longer gripped the bar as firmly. I too had marine grease on my bushings. I'll update once I clean them off.
dsc888
#74
My Comptech RSB made no noises for the first couple of months, then started clunking over bumps. I removed and replaced the RSB with the original - no clunk. I did a search on this site and reinstalled the Comptech RSB after using marine grease. Worked great for 2 weeks - then clunks again. Works great, but I can't stand the noise. I am currently using the OEM again.
The rubber bushings from Comptech are much harder than stock. I wonder if a softer bushing would dampen the clunk? I guess we should all call Comptech and start complaining.
#75
dsc888
#77
Originally Posted by xcelir8TL
Is there a way to get an Energy Suspension bushing that mimic's that as close to CompTech's as possible and use that?
marcelft
07-10-2018 06:17 PM
oyayjoe
09-12-2015 04:40 PM
