Less body roll
Less body roll
I have an 04 5 a/t. I've searched around, and found a little bit of info. But would just a drop decrease body roll quite a bit? I was looking into sway bars as well, but the FSW sounds like a pita to install.. I'm not looking to make my tl into a race car, but hate that feeling around corners. If I do drop, I'm looking to get some tein coils.
The following 2 users liked this post by justnspace:
Luketic (03-18-2014),
Undying Dreams (03-18-2014)
i'm going off of memory; because when i researched and installed the progress RSB, it was 3 years ago...
i think there's a comptech bar that is STIFFER than the progress bar. but I think it has been discontinued or something, not sure.
however, you really dont want to go VERY stiff, since you dont have a way to balance it out, ie: thicker front sway bar. (i think we have ruled it out because of its difficulty to install.)
the progress rsb is i believe 22 or maybe even 24mm thick..again i forgot. but once installed it does take the lean out of the car when cornering. and if you do set it up on full stiff, you will even get a little bit of 'lift off throttle oversteer' which is fun!!
Chapter Leader (Southeast Region)
The progress rear sway bar is 24mm. Since you have a base automatic run the sway bar on the soft setting . If you want to run it on the stiff setting you should get a type s fab or h&r front sway bar.
The following 2 users liked this post by Stephen00TL:
justnspace (03-18-2014),
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
