Largest tire for Stock 2002 Type-S
2002 TL-S
Hi all -
Was part of longer thread below about New Tires. Just wanted to let everyone else know for future reference.
In the last week, I have had 3 sets of Michelin Pilot Sport A/S tires on my 2002 Type-S (stock rims). I won't bore you with the details of how and why I did all this, but here is how they work out:
Factory Standard Tires - Pilot MMX4
Size: 215/50/17 - Fits 6.5 rim. 25.5" total outside diameter.
Result: Works fine.
Size: 245/45/17 - Ffits only 7.5 rim. 25.9" total outside diameter.
Result: Seems fine, but is dangerous and too wide for wheel.
Size: 235/50/17 - Fits 6.5 rim. 26.6" total outside diameter.
Result: Overall diameter too big - RUBS WHEN SPRING IS COMPRESSED.
Size: 225/50/17 - Fits 6.5 rim. 26.1" total outside diameter.
Result: Works fine.
Moral of story:
215/50/17 or 225/50/17 are the only size All-Season High Performance Tires that fit.
See ya.
Result: Works fine.
Result: Works fine.
Moral of story:
See ya.
2002 TL-S
Jeez - sorry. Just trying to add some value. I knew 225/50/17 would work from previous posts, but I found quite little on the 235/50. I *did* do a search on the 235/50/17 and all I found was:
"Circumference wise, 235/45/17 is the best and 225/50/17 will also work. I'd stay away from the 235/50/17... too big. The only concern is you might be pushing it with a 235 on a 7" rim. I think the safest is the 225/50/17 on the CL-S 17x7 rim.
You might have some mild trimming on the rear (ie plastic tab)...."
The information above is not 100% accurate, at least for my purposes. 235/45 in the Pilot A/S requires a 7.5" rim. So for the brand tire I wanted it won't work. I was looking for tires that fit 6.5" rim obviously. 235/50 in the Pilot A/S is fine for the 6.5 rim according to Michelin - but it rubs on the front, not the rear, from the older log. Plus the note is for the CL-S, not the TL-S, so I wasn't sure about the trimming being accurate. I just wanted to let folks know that 225/50 is the biggest Pilot Sport A/S that will fit a 2002 TLS.
Moderator Alumnus
2002 TL-S
Lots of people put on larger wheels and/or tires. Not all of these will match the factory outside diameter exactly. Some will be larger, some smaller. Especially if you are looking at 18 or 19" wheels. And I am aware the speedometer may be off a tad - no big deal I'll just keep an eye on it. Based on the diameter of the tires and the # of revolutions per mile, comparing my Pilot A/S tires to the stock MXM4's comes out to about 12 feet per mile difference - not too much presuming my math is correct.
First, the Pilot Sport A/S, while in many opinions are the best tire made (see tirerack.com), are *NOT* available in the stock size (215/50/17) - period. You *HAVE* to get a different size tire from stock, if these are the ones you want. These in particular are consistently ranked as one of the best all-season sport tires available, and are what I wanted.
If you want another excellent high performance all-season tire, like the Sumitomo HTR+ or the Yokohama AVS ES100, these are available and will fit fine on 215/50'17s. They are also much cheaper, and are what I would have likely bought had #1 below not been true.
I personally got these because:
1. They were free -
2. They LOOK better to me - I like the wider profile tires.
3. They fit on the stock wheel.
I don't know how a larger better tire would reduce overall performance though - seems the wider tread would put more tire on the road. I have never heard that if given the choice between a 215 or a 225 - take the 215.
1. They were free -
2002 TL-S
I guess I should have been more specific in my last post. 225/50/17 is not the largest size Pilot Sport A/S that fits the stock wheel - it is the *ONLY SIZE* Sport A/S that fits the stock wheel. These specific tires, are *NOT* available in the stock size (215/50/17) - period. You *HAVE* to get a different size tire from stock, if these are the ones you want. These in particular are consistently ranked as one of the best all-season sport tires available (see tirerack.com), and are what I wanted.
If you want another excellent high performance all-season tire, like the Sumitomo HTR+ or the Yokohama AVS ES100, these are available and will fit fine on 215/50/17s. They are also much cheaper, and are what I would have likely bought had #1 below not been true.
1. They were free -
I don't know how a larger better tire would reduce overall performance though - seems the wider tread would put more tire on the road. I have never heard that if given the choice between a 215 or a 225 - take the 215.......
Cheers to ya.
1. They were free -
Cheers to ya.
Moderator Alumnus
Cheers to ya.
Cheers to ya.
1fatcrxnem1
22
06-01-2018 01:23 AM
