Koni Yellow perch question
My first ricer
I was under the impression the middle setting was stock height, lowest is 20mm down, highest is 20mm up, maybe it's 15 not 20. I have stock springs on the lowest setting and it's not very low, the drop is barely noticeable, so unless you have super low springs I'd go with that.
-------Tim-------
^curious why you went higher on the perch level? If I understand this correctly, you have Tein S-Tech springs (~1.5" drop), and raising the perch to the highest, your overall drop is around 1" or less? Your car looks great! You are riding on 18" wheels correct?
I have the SP3 (5 perch model koni), second to lowest perch front, lowest perch rear, with H&R sport springs, On stock wheels.
Slpr04UA6 (02-04-2015)
Former Sponsor
This is an interesting discussion. We always tell people to put the perch in a location that matches the stock damper's perch location. We discourage people from calling the perch "adjustable" because they don't work the same on all cars...
Did you know the Koni shocks for 1g TSX, 3G TL, and 7g Accord are all the exact same parts? But these cars have different "baseline" perch heights. This is why the Konis have different height setting...not so as to be adjustable per application.
It is a nuance thing, and of course you can use the different settings to customize the car more. But we, again, warn people that there may not be an ability to get even or balanced settings on all cars if you don't use the setting meant for your car.
Your Friendly Canadian
Received 1,485 Likes
And if you were to set the shocks on their "lower" perches, you would just "add" that height difference to the advertised spring drop to get your total drop from stock?
Former Sponsor
So if you were to pair them with aftermarket (i.e. shorter) springs, does that mean the highest perch on the KONIs will result in the advertised drop of the springs alone?
-------Tim-------
I was always under the impression, the perch setting the Koni's came out the box, would yield the advertised drop of lowering springs. On my Sp3's this was the 3rd perch from the bottom (out of 5 perches total). ?
What would the optimal perch be for the TL Marcus? Lowering spring or not...
Former Sponsor
Granted, there is the ability to move the perch so that leave room for interpretation as to where the "optimal" setting is, especially when you factor in all the different springs and tastes out there.
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
SUPRMN84
10-07-2015 09:46 PM
