Koni Orange missing parts?
Doing the shocks and springs on my 2006 TL. In putting the Konis together I have no Bump Stop Plate. It is the washer between the Bump stop and the lower of the two similar Rubber Bushings.
Was it supposed to be included with the Konis? The Cup and Collar that were the old bump Stop Plate were unremovable from the OEM shocks. They were Rusted solid on and I had to cut the top washer
and nut off and cut the shock spindle in half to remove the bump stop itself. Damn salt and snow up north here. Any ideas if I need the Bump Stop Plate or not or if I can pick a comparable one up locally
for the Koni Orange that I have? Thanks!
Looks like they want you to use the OEM dust cover washer to retain the bumpstop.
The bump stop bead on the shock shaft isn't tapered like the stock one, is it?
If it is tapered, then you need the bumpstop washer. I'm guessing KYB and other companies make replacements.
I'm surprised you can't remove your old one with a hammer.
Counting from the bottom up...
shock body
bumpstop
(bumpstop washer?)
dust boot
dust boot washer
tophat bushing 1
top hat
tophat bushing 2
tophat cup washer
nut
shock body
bumpstop
(bumpstop washer?)
dust boot
dust boot washer
tophat bushing 1
top hat
tophat bushing 2
tophat cup washer
nut
shock body
bumpstop
(bumpstop washer?)
dust boot
dust boot washer
tophat bushing 1
top hat
tophat bushing 2
tophat cup washer
nut
shock body
bumpstop
(bumpstop washer?)
dust boot
dust boot washer
tophat bushing 1
top hat
tophat bushing 2
tophat cup washer
nut
Note to others removing the shocks, front and rear. Be sure to note the Damper Mounting Base orientation to the shock itself as you reassemble. The front requirest the single bolt mount inboard in line with the notch in the back of the shock for the pinch bolt. The rears require the bolt mount to be parallel to the Damper Mounting Base.
Thanks to the other poster on performing a F/R Shock and spring replacement. Dropping the roll bar in the rear simplified removal for sure!
Grinch Out!
lumyeinjun
14
07-19-2010 01:19 PM
bforbrian
3G TL Photograph Gallery
192
04-25-2010 08:37 PM
NYCLS
06-16-2003 11:54 AM
