Kaotik Z5 18x7 +42 Hub Centric or not?
'99 Acura 3.2TL
hey guys the wheels im buyin' are offered in 2 versions, one is hub centric with a center bore of 60.1 and the other is not hub centric with a center bore of 72.6
which one should i get and why?! what's the difference between the two?
thanks!
@cUr@-TL
thanks!
@cUr@-TL
hubcentric means it's centered around the hub and it's the best because it will spin round. the larger center bore is meant to fit a wider range of cars and you would have to use lug nuts to center the wheel. i am not sure what our center bore is though and 60.1mm might not be the one.
