Just got an alignment...how are these readings?
Old 05-27-2008 | 08:36 PM
FiveLiterCheater's Avatar
Just got my alignment redone...feels much better, but i'm curious to see how these readings are compared to others...Still kind of confused why my camber is different from left to right by .4*
Front Left Front Right
-1.1 Camber -1.5 Camber
3.1 Caster 2.9 Caster
.01 Toe .03 Toe
Rear Left Rear Right
-2.0 Camber -2.4 Camber
.05 Toe .06 Toe
Thrust Angle: 0.00
Steer Ahead: 0.01
Old 05-27-2008 | 09:05 PM
enigmaos's Avatar
Too Fast TOO FURIOUS
same here.
Old 05-28-2008 | 09:42 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
well i suppose it will even out when you sit in the car.... did you have anything in the trunk?
ps. tom... you see his toe numebrs..... tray is super anal no.... zero'd out all the way around
none of that point anything... just 0.00
Old 05-28-2008 | 10:01 AM
datplayaz's Avatar
the rear toe should be a little bit closer to zero, if not at zero... but other then that it looks ok
Old 05-28-2008 | 12:25 PM
01tl4tl's Avatar
IMO- once the camber goes past negative 1.5 degrees and is at neg 2 degrees- you need to think about rear camber kit- 150$ plus 1 hour to install both sides
You will be putting some wear on the tires at the current setting
ON toe readings- the end result is the thrust angle- which is what we really care about being zero- thrust alignment is different at how it arrives at the conclusion
My 01 on tein ss does that same thing with camber- the car does not sit exactly level or weight equal on each corner- so camber is different. You can raise or lower a corner slightly to adjust it if more than .5 differance, otherwise just run it
OP- contact MrHeelToe or Excelerate for the rear camber kit, will require an alignment again, but thats way cheaper than tires
Old 05-28-2008 | 01:33 PM
enigmaos's Avatar
lol, yeah, all zeros except one with -0.01.
Old 05-28-2008 | 06:37 PM
leedogg's Avatar
RAR
I just got my allignment as well:
LF RF
-0.7 -0.6 camber
.35 3.1 castor
0.0 0.0 toe
LR RR
-1.7 -1.6 camber
0.04 0.04 toe
MrHeeltoe
20
02-23-2023 01:54 PM
Jimmy_D
10-07-2015 11:52 PM
MrHeeltoe
09-29-2015 10:43 PM
hashbrown
09-29-2015 12:13 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Just got an alignment...how are these readings?
