Installing ASPEC suspension tomorrow!
Old 02-21-2014 | 07:23 PM
JUSPEN80's Avatar
Talking Installing ASPEC suspension tomorrow!
Finally got my ASPEC suspension and will be installing it tomorrow since it will be a sunny 60 degree day! I have done alot of research on here about the install, opinions and results. I am really excited and hope all goes well..Wish me luck!!
Old 02-21-2014 | 07:34 PM
Conan O'Brien's Avatar
cool. take before and after pics. curious to hear how it rides.
Old 02-21-2014 | 07:38 PM
JUSPEN80's Avatar
Will do!
Old 02-22-2014 | 08:03 AM
JDM RICe's Avatar
Any specific reason why you chose those rather than say a Tein Street Basis setup or Koni Yellow w/ stock springs setup?
I'm shopping for a new setup and not too far from pulling the trigger.
Good luck with install!
Old 02-22-2014 | 10:04 AM
subinf's Avatar
One on the right for me
I chose the aspec over anything else because it was less expensive and exactly what I needed firmness wise.
Old 02-22-2014 | 11:52 AM
AcuraIntegTL's Avatar
keep it clean
When I was installing my Aspec suspension I found it difficult to work the strut assembly into place. I'm not sure if it was because I had my TL lowered on Megan coilovers prior, but it helped to take the FSB link and RSB link off when I was putting in the new Aspec struts on the front and rear respectively. Also, another set of hands would be very helpful, but I'm sure it can be done by one person.
For me, I chose the Aspec because I was tired of watching for dips, pot holes, and other obstacles on the road. This is my third suspension on my TL, other than stock.
1) Tokico HTS Dampers with H&R sport springs, and base top hats. This is a great setup if you're looking for something similar to Aspec suspension, but a little lower and ability to adjust damper settings. Might try this again, but with Aspec top hats, when the Aspec struts go bad.
2) Megan Coilovers. Rides nice and you can slam the TL! Has damper adjust too, but I got tired of it because of reasons stated earlier. Sure I could have lifted the suspension and adjust damper settings again, but thought they would be better off with someone that could and would really use them. So, I sold the coilovers to another azine member.
3) Aspec suspension. Has everything that I was looking for, but another .25" lower would be nice. Ride is firm enough for me, and still takes corners well when I want to have some fun. Also, I like the fact that it was engineered by same guy that worked on the NSX. Which goes to my final reason why I went with Aspec, it's made by Acura for the TL.
Old 02-22-2014 | 02:00 PM
tomlinsonj's Avatar
^This. ASPEC is a great upgrade that adds more sport-feel to daily driving. It's firmer than stock but certainly not harsh. Plus it's engineered specifically for the TL.
Old 02-22-2014 | 07:29 PM
fordcourier72's Avatar
I feel dumb for asking, but what does the aspec suspension look like? Or, how do you tell the difference between stock and aspec?
Old 02-23-2014 | 05:03 PM
JDM RICe's Avatar
Thanks for the reply. You're making my choice tougher!
Old 02-23-2014 | 07:30 PM
cokorote's Avatar
@ AcuraIntegTL You can lower .25"with the aspec with the koni yellow.
Old 02-23-2014 | 07:46 PM
Grimm Reeper's Avatar
5th Gear
can't wait to see before and after pics.... I've been debating on which direction to go with my suspension.
Old 02-24-2014 | 12:13 PM
cokorote's Avatar
You wont be able to see the difference in drop with the aspec suspension.
Old 02-24-2014 | 08:20 PM
Due_Diligence's Avatar
Don't mean to thread jack, but if I buy the OEM assembly front shocks is it basically unbolting the old shocks then rebolting on the new shocks? I wouldn't have to mess with the springs at all correct?
Old 02-25-2014 | 06:51 AM
Turbonut's Avatar
Depends on what you purchase. If you elect just the shock, then the spring will need to be changed over, but if you purchase the shock assembly it will be an easy replacement as it comes as an assembled unit.
Old 02-25-2014 | 12:52 PM
cam_2's Avatar
Ditto on thread jacking, but was curious where you bought the A-spec components
Old 02-25-2014 | 02:26 PM
Turbonut's Avatar
Don't know where the OP purchased the set, but:
More than 10 available:
http://www.ebay.com/itm/New-OEM-Acura-2007-2008-TL-A-Spec-A-T-Lowering-Suspension-Kit-08W60-SEP-202A-/171245053425?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3ATL&hash=item27df0025f1&vxp=mtr#ht_942wt_731
Last one:
http://www.ebay.com/itm/2004-2006-ACURA-TL-A-SPEC-SPORT-SUSPENSION-FACTORY-OEM-/370803467913?pt=Motors_Car_Truck_Parts_Accessories&hash=item56559be689&vxp=mtr#ht_525wt_731
cam_2 (02-27-2014)
Old 02-25-2014 | 02:48 PM
story.customz's Avatar
3 day install so far for OP?
Old 02-25-2014 | 09:44 PM
le^2
02-18-2021 10:44 PM
02-25-2020 09:57 AM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Installing ASPEC suspension tomorrow!
