Installed H&R Coilovers & Progress RSB
Wocoomrd
At first, they dropped it 2.5". It was too low so I went back and they made the total drop to be about 1.5". The difference is night and day. Car feels like it's planted to the ground. The handling doesn't compare to the 330i I had, but it's AWESOME for a FWD car.
I would highly recommend it! Only annoying thing is the squeaks from the back of the car. Still trying to figure out if it's the RSB squeaking or the rear suspension.
Pics will come next week!
AZ Community Team
Received 7,770 Likes
Nice!!
Post Pics!!
Post Pics!!
LIST/RAMEN/WING MAHSTA 짱
This isn't the case with my personal car and I have the Progress RSB, but when people change out their RSB's, they sometimes don't grease up the bushings enough, and a short time after installation, the RSB bushings squeak as well. Hope this helps!
08 TL Type S A-Spec
This problem seems to be happening a lot once TL's are dropped.
Did you do BOTH the Progress RSB + Springs at the same time??
If NOT, did you notice the sqeak/rattle after the springs were installed?
I have had my Progress RSB for about 1 month.......NO ISSUES. I put a TON of GREASE on the new bushings........the little tube + some extra of my own.
I think it is the springs. It seems that the TL's don't like drops to the suspension OR you have to do a very SMALL drop.
I am in a position where I WANT A SPRING KIT, but I am afraid of the rattles/squeaks they can cause.
I am thinking about the Eibach Pro Kit (1" drop F/R) because it is such a SMALL drop.
I called Eibach, and was told that some springs (from other companies) that drop the car too much, put too much added "stress" on the suspension components = rattle/squeak/wear out faster IF the drop is too much.
Just my
Just my
Wocoomrd
I did both at the same time. The guy that installed it said that it's the RSB. However, then it was dropped 2.5", it squeaked A LOT but once they jacked it up 1.25", it didn't squeak as much.
WEAKSAUCE !!!
How do you guys like the H&R suspension? I was thinking these between the Tein SS, did you guys install rear camber kit? if so what brand? If not i am thinking koni yellows + maybe eibach or h&r or tien springs...
AZ Community Team
Love the H&R Sport Springs. Stock Shocks, but I hope to get Kopi's someday (
) and drop the car about another 1/4".
No Camber kit. Camber on the right (F & R) is actually still in spec; Camber on the left (F & R) is barely out. Corrected Toe with an alignment.
Wocoomrd
I defiantly need a rear camber kit because the guy at the shop said the rears are off by about -.3, or something like that.
I don't think you can go wrong with either. My BMW had eibach springs and I decided to get H&R with this acura. I will have pics up when after I get my car washed.
Team Anthracite
anyone tried both Tein SS and H&R Coilover?.... still deciding... i need a good firm one so i can track properly =) i like stiff =)
used to it on the NSX when tracking
once you figure out WHERE that SQUEAKING NOISE IS COMING FROM...let me know ASAP!!! lol I have that problem too, but its been over a year...it comes and goes...
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Here I come!
Has anybody tried or heard of Dropzone coilovers? Also. how can u tell if the coil over is not just an imitation sleeve-over?
Former Sponsor
Squeaks?????? Not sure what you guys are doing the suspension should not be making noise. You know I am still somewhat suspicious of all this lube being squirted all over the place too. You should not need tons of lube. There is only a small area where the grease actually fits in the bushing. Putting more just causes it to squish out and squished out lube is doing no good whatsoever. However much squishes out, that how much TOO MUCH you put in there.
The progress bar comes with a little tube and you only really need about half what they give you. The comptech bar has a waxed rubber bushing that needs no lube at all.
I installed some on an integra. They are junk.
Here I come!
I'm looking to get a 2.5"-3" drop. Which coilovers are good for that at a decent price? I'm not really looking for top of the line, just decent.
A-spec steering wheel ftw
a-spec suspension/drop and have been fine with it for the past 4 years. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
i dont know what squeaking is even possible with the Progress RSB, everything is pretty straight forward and the energy bushing is pretty good quality polyurethane.
seems so odd that alot of ppl have seemed to have this issue.
Former Sponsor
I agree. Mys suspicion is that people may be over-lubing, or using the wrong lube. And really switching to ES bushings should not be generally necessary either. I don't see whats wrong with the ones that the bars come with.
Marcus
1fatcrxnem1
22
06-01-2018 01:23 AM
BoricuaTL
04-08-2016 01:08 PM
MonkeyTrucker
09-21-2015 06:15 PM
