Installation of Tein Basic Coilovers help
Old Jan 13, 2010 | 12:23 AM
acuraTL_916's Avatar
New to the car world and in need of some help! Sites or tutorials for help on installation would be great thanks all!
Old Jan 13, 2010 | 11:22 AM
04TL4P3's Avatar
look at the sticky thread named 3g garage wheels/tires/suspension, it should be the 3rd post down from the top...there is a link in there to a DIY for the a spec coil overs and there is a link in that thread that has the install instructions from acura. I just used that and it was really helpful...
Old Jan 15, 2010 | 11:04 PM
tragichero's Avatar
My Other Ride is a Huey
Use the garage section, there are 1 or 2 write up there. I read them over a few times to make sure I knew the installation fairly well before I installed mine. They are pretty much spot on! Any specific questions on the install, i'm sure people will chime in!
Good luck!
Old Jan 16, 2010 | 05:01 AM
Maddizm's Avatar
Buy all the top hats and OEM suspension components that you're gonna have to reuse. It will make the installation so much faster and easier... I feel.
Old Jan 16, 2010 | 05:17 PM
modelcarnut's Avatar
TRAVIESO
Believe it or not, the hardest part about doing the suspension install is taking off the back seat I did mine in less than 3 hours.
Old Jan 21, 2010 | 03:31 PM
LiquidX's Avatar
8th Gear
Simple, besides the rear seat removal to get to the rear struts. Fronts only need the bolts around the struts removed, and 2 bolts under the car: one holding the fork to the lower arm and the other holding the fork to the strut. The rear is 1 bolt under the car that holds the strut to the knuckle and the bolts behind the rear seats.
Old Mar 24, 2011 | 11:50 AM
CaliWowie's Avatar
06 ThugLuv
Im looking into installing coil overs and came across ur 2 cents on it..besides top hats what other OEM components would you recomend to purchase before i install the coil overs??
thanks
Old Mar 25, 2011 | 08:58 PM
VolkingTL's Avatar
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/self-installed-spec-suspension-3g-garage-d-058-a-568429/
Read it, memorize it, print it, whatever you do, follow the instructions.
BoricuaTL
Apr 8, 2016 01:08 PM
james357
Feb 13, 2016 02:37 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
mugen_kid
Nov 13, 2015 10:38 PM
nanos
Nov 12, 2015 08:41 PM
