If I can get 18" momos for $300 should i get it, or should i just get 19"
Does 18" make your car look that much better, or should i just invest in 19"..And if i do get 19"s will i have any problems turning, scratching the tire, etc.,
IMO 18's don't look that much bigger then stock tl-s 17 inch rims. I would go 19 inch. As long as you get the proper size rim, tire and offset you shouldn't rub. MAX rim size = 19x7.5 w/ 235 35 r 19 rubbers with an offset of +50 to +52. that would be the ideal 19 inch setup for our cars. from personal experience, i have that setup and lowered and dont rub at all even w/ 5 people in the car. Speedo stays the same too because overall diameter is the same.
Personally I would do 18s. There is less chance of rubbing, you may not have to roll your fenders, they are less expensive, you can go with a higher series of tire for less chance of rim damage, lighter weight (depends on what brand/type of rim you get) and so on. Ultimately it is just preference. Speed and performance or looks and pimpedness?
handsom-hustla
11-13-2015 05:04 PM
InFaMouSLink
10-30-2015 09:43 AM
InFaMouSLink
10-27-2015 06:51 PM
