I need a camber kit, What should i Get? help.
B A N N E D
:me what you guys think i should get, i have a 05 TL lower on tein s-techs on 19"s. let me know the brand , price and where i should buy it.
what is your camber reading after the spring install- that will determine which parts you need. Its good to have a little bit of negative camber- for cornering~
azine vendors MrHeelToe and Excelerate are both good places to buy- tell them you are from acurazine! See their threads by clicking Off Topic at top of this page- then Sponsored Sales
Phone calls or email gets faster reply than a message left on any of the threads.
you can only adjust the TOE on the stock TL
With your slight drop- what was it- 1 inch?, you will alter the toe, and the camber will go negative-
If you want to adjust the camber back to spec or to max negative limit, then you install a camber kit
You need to get a readout of where its at today, if the neg is close to limit- then set the toe and let it go, example limit neg 1 and you are at neg 1.3, thats ok there.
If the camber is negative 2 degrees- you need camber kit!
and get a better alignment shop that knows TL and isnt afraid to use their brain over the computer--the laser alignment machine guys are trained that it has to be `in the green` or it needs very expensive parts and labor~~~
emailnatec
29
09-28-2018 04:27 PM
