I don't see TPMS !!! HELP
Old Aug 21, 2012 | 07:49 PM
RickBordas's Avatar
Hey guys im from Dominican Republic and i recently buyed a 2006 Acura TL with NAVI (in Dominican Republic the navi doesnt work but... its pretty cool anyways) the thing is the Multi-Function Display doesnt show any TPMS message, i dont see if my car really has the TPMS system.. i have the manual right now and i press the ">" three times like the manual said and nothing... .the thing is that :
Does my car has the TPMS installed?
Are the sensors ok?
I have 235/45/R17 (like Acura says)
How i can detect if my 2006 Acura TL has the sensors in the wheels?
Like the topic says.. I dont SEE in my CAR ANY TPMS word in the Multi Function display..
"Check TPMS system" doesnt show too...
Thanks..
Old Aug 21, 2012 | 08:14 PM
Deerole's Avatar
2006 dont have TPMS
Old Aug 21, 2012 | 08:26 PM
RickBordas's Avatar
Dude .. the Guide Manual says that the car DOES have the TPMS system.. so Acura was wrong about my car and put a wrong guide manual?...
Old Aug 21, 2012 | 10:47 PM
Ron A's Avatar
Administrator
Welcome to the forums.
2006 was the first year for TPMS in the TL's, so if it's a 2006 it should have it.
Check your vin here to make sure that you actually have a 2006. https://acurazine.com/forums/vindecoder.php
The wheels should have a flat area around the valve stem.
Did you buy it in the US? Is it possible it was made for export so it doesn't have the TPMS?
Old Aug 21, 2012 | 10:50 PM
Deerole is wrong.
2006 did come with TPMS.
I agree with Ron A.
Old Aug 21, 2012 | 11:36 PM
A SiQ TL's Avatar
OP, Does your rim look like this
Specifically the indent around the valve stem.
Or does it look like this,
notice these are the same rim without the indent around the valve stem
The top pic is what your TPMS wheel should look like.
I remember seeing an '06 on a dealer lot around here years ago that had 2 '04-05 rims.
Old Aug 23, 2012 | 07:04 AM
RickBordas's Avatar
2006 Acura TL 4dr Sdn AT
VIN: 19UUA66286A025307
That's my VIN... i have an original 2006 Acura TL.. dude i dont understand very well about the tire and the wheel thing... could you be more specific with a specific line in the picture that indicate the sensor ( ------>) or something?
Another thing... if anyone has carfax it would be great to investigate my VIN... in DR we dont have access to that
Old Aug 24, 2012 | 12:14 AM
sauceja's Avatar
Desert Life Sucks!!
Old Aug 24, 2012 | 12:41 AM
MissAlyyTL's Avatar
Si no puede acceder a carfax en DR es probable que no tenga la información sobre su coche. Solo si era de aqui.
Damn its been a while since I've written in spanish, fingers crossed i spelt correctly LOL. Wowo, this bordem/insomnia is a killer lol.
Cliffs: if they cant access carfax over there, they prob don't register the info into their database...(is that a safe assumption?)
Old Aug 24, 2012 | 03:22 AM
O7acuraTL's Avatar
If the valve stem looks rubber and you can wiggle it with your fingers, you DO NOT have a TPMS sensor on the rim. If the valve stem is metal and you can not wiggle it, then you DO have a TPMS sensor. The car could also have an in-direct TPMS system. An in-direct system does not have a TPMS sensor on the rim. It uses the abs system. When the ABS detects a wheel spinning less than the other 3 tires, the TPMS light will come on.
Old Aug 26, 2012 | 10:09 AM
RickBordas's Avatar
THESE ARE MY WHEELS...
So.. the valve is there... could be the sensor??
Old Aug 26, 2012 | 10:22 AM
UA6~RBP's Avatar
-Brandon
The previous owner of your car could have taken them out if he got new wheels.
Old Aug 26, 2012 | 10:27 AM
RickBordas's Avatar
Ok... the most important thing is that the valve is there so ... i just have to buy the sensors right?
Old Aug 26, 2012 | 10:49 AM
its odd that the MID doesnt indicate a problem.
when my TPMS in the wheels go out, the dash clearly says! WARNING WARNING WARNING WARNING WARNING
Old Aug 26, 2012 | 11:31 AM
RickBordas's Avatar
yes but probably as the sensor isnt installed on the car, the MID couldnt display anything because the MID cant give an information that doesnt have.. so... i can understand perfectly that... I have the valve but not the sensor, as I have unavailable the sensor then the information can not be seen
Old Aug 27, 2012 | 06:45 AM
^if it cannot be seen, the MID would still go crazy.
can you take a picture of the MID showing the tire pressure screen?
Old Aug 27, 2012 | 07:19 AM
RickBordas's Avatar
Thats the problem bro.... the MID does not show anything about Tire Pressure... it shows these:
Trip A, Trip B, Oil Life, Outside Temperature, HandsFreeLink and KeyLessMemory Settings...i dont have the "Tire Pressure" Option!!... thats what i dont understand...
Old Aug 27, 2012 | 01:42 PM
lleron's Avatar
Is it possible that he has an 04-05 cluster swapped in..? If the car was imported it's possible they swapped the cluster to make the car appear as if it had fewer miles than it does.
Old Aug 27, 2012 | 04:23 PM
RickBordas's Avatar
BINGO..... I saw the Car at Carfax and everything is great EXCEPT..... the ODOMETER... Now has 70,000 miles and the last odo registered was 100,000..................
And another thing.. when i swish the key to ON (II) possittion it does not show the Low Tire Pressure light)... damnnnnnnnnnnnnnnnnnnnnnnnnnnn
Old Aug 27, 2012 | 04:29 PM
RickBordas's Avatar
So.. the next question is.. where can i buy the original cluster 2006? :p
Old Aug 28, 2012 | 08:25 AM
RickBordas's Avatar
anyone?
Old Aug 28, 2012 | 09:13 AM
post up your vin number.
take photos of your cluster for us.
this will help us determine if you have the correct cluster.
Old Aug 28, 2012 | 10:34 AM
RickBordas's Avatar
ON Position:
Started
Old Aug 28, 2012 | 01:35 PM
A SiQ TL's Avatar
yeah, there should be a flat/low tire indicator light above the side airbag off light.
I bet lleron is right, you have the wrong cluster.
Old Aug 28, 2012 | 02:32 PM
RickBordas's Avatar
but my question is.. i can resolve it just buying a original 2006 acura tl cluster? just that?
Old Aug 28, 2012 | 03:04 PM
paperboy42190's Avatar
should be able to....find one on ebay
Old Oct 7, 2012 | 08:31 PM
RickBordas's Avatar
Done buddys... i just had to bought an original used 2006 cluster A/T and everything works perfect
PICS...
Attached Thumbnails I don't see TPMS !!! HELP-img-20120920-00413.jpg   I don't see TPMS !!! HELP-img-20120921-00415.jpg
Old Oct 7, 2012 | 08:41 PM
firstacuratl's Avatar
邵樂百
Good job RickBordas ... way to take the reins and get the problem fixed properly! Well done ...
Old Oct 7, 2012 | 09:03 PM
Bearcat94's Avatar
AZ Community Team
x2
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
bailey24
Nov 21, 2015 08:43 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
lland
Oct 4, 2015 04:47 PM
GhostTL09
Sep 19, 2015 01:57 PM
