Hubcentric rings for iForged aero
Does anyone know what the hubsize for the iForged Aero is?
I just got Ichiba 5mm hubcentric spacers but I might need some hubcentric rings.
Does anyone know where I can get a pair of hubcentric rings with the proper size.
LIST/RAMEN/WING MAHSTA 짱
Our vendor which sells them is b2autodesigns. Here's their hub ring thread: https://acurazine.com/forums/sponsored-sales-group-buys-10/hub-rings-your-aftermarket-wheels-helps-reduce-wheel-vibration-703581/
As for the iForged wheel hubsize, I think the best bet is to contact iForged. Hub rings can be made to any spec.
My Garage not
1 Post
do you have the wheels? just take a ruler and measure it. get the plastic hubrings on fleabay. the fleabay search keyword is "hubcentric ring".
the black plastic polycarbonate rings that all vendors sell for all wheels are all the same. i'm all for supporting board vendors but $30 for hubrings is like a jack move.
Bay Area's Finest
1 Post
I am a bit of a noob with spacers but can you tell me why you would need hubcentric rings when you have ichiba hubcentric 5mm spacers? I have an 05 TL 6MT and I am looking to get Ichiba 5mm V1 spacers. Should I get the Ichiba's or is there anything better that I should use?
I agree with above.... You bought hubcentric spacers. Which means that it has the hub ring built in to the spacer. You didnt measure or contact manufacturer of wheel before you placed the order.
New shoes on my
With 5MM spacers, you will still need hub rings. When you put the spacer on, a little bit of the hub will still hang out, enough to get the hub ring on there to center the wheel. All the hubcentric spacer means is that the spacer will also line up with the hub, further reducing any chance of vibration.
mtl_ilx
09-03-2015 09:48 AM
