HT spec coilovers question
Old Mar 9, 2012 | 06:04 PM
RU_JELLY's Avatar
Redwood Original
I am going to raise my car up about half to 3/4" this weekend and had a question. I heard you can raise it up by just spinning the top perches instead of removing the forks and all that crap. Will this make the ride more or less stiff? The terminology on htspecs website confuses me. Also which way would i spin them to the right or left? anybody have experience doing this ?
Old Mar 9, 2012 | 07:14 PM
Slpr04UA6's Avatar
-------Tim-------
Maybe this will help? I don't have experience with coilovers, but here is a good writeup!
https://acurazine.com/forums/showthr...stment+dummies
Old Mar 9, 2012 | 09:14 PM
SharksBreath's Avatar
BANNED
spin the top rings to the left. you have the spanner wrench right?
just make sure you measure the threads afterwards so that they're all level.
it won't change the ride quality, but you may want to get an alignment bc you're messing with your suspension, just to be on the safe side.
Old Mar 9, 2012 | 09:38 PM
RU_JELLY's Avatar
Redwood Original
Thx sharky
Old Mar 9, 2012 | 10:30 PM
proimport's Avatar
+1 for sharksbreath
i have the ht spec and he is right
Old Mar 10, 2012 | 02:29 AM
o666los's Avatar
Just loosen the bottom perch and spin the entire shaft/spindle to desired height because if u spin the top perch which is the preload then ur car is going to ride like sh!t bro
Old Mar 10, 2012 | 05:45 AM
TLDude876's Avatar
Chapter Leader (Houston)
Originally Posted by proimport
+1 for sharksbreath
Not so sure about these suggestions as you do not want to touch the two top most rings at all.
^what this guy said.
Old Mar 10, 2012 | 07:43 AM
EATSLEEPRACE's Avatar
6SPEED FEVER
DO NOT ADJUST FROM THE TOP!....your changing the spring perch...it's support to be at 8 inches I think...any higher the stiffer it gets.....
Do it right from the bottom collar.
Old Mar 12, 2012 | 01:36 AM
H23Accord's Avatar
iWhine
Like this:
Old Mar 12, 2012 | 05:31 AM
RU_JELLY's Avatar
Redwood Original
I adjusted from the top yesterday an unlike some of you thought my car doesn't ride like shit. Actually the opposite. It is a little stiffer which I wanted anyways and rides great. It was however still a bitch and took about 800 hits with a hammer and flathead so next time I'll be adjusting the bottom if needed. Thx for the help everybody
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
BoricuaTL
Apr 8, 2016 01:08 PM
datadr
Sep 12, 2015 09:12 PM
