HR Sway bar
RAR
HR Sway bar
Does anybody have one? I'd like to hear an opinion. Especially if you've compared it with a comtech...
Those teflon bushings with a 'lifetime greasing' are what I really want...
Trucki!!
They look alittle pricey compared to a comptech, but they make a front and rear for the 3rd gen
http://www.livermoreperformance.com/...honda_arb.html
H&R Sway Bars
H&R Sway Bars are the perfect compliment to H&R Springs, Coil Overs, Performance Shocks and Cup Kits.
Designed to reduce body roll, increase lateral stiffness and improve handling, H&R Sway Bars are crafted from a special 50CrV4 spring steel that is both stronger and more resilient than competitive sway bars. H&R Sway Bars are bent on proprietary machines designed by H&R that seamlessly produce beautiful complex curves making H&R Sway Bars a perfect fit for your vehicle.
Also included are H&R exclusive bushings made from a Purim / Teflon composite that eliminates squeaks, and don't require lubrication. That means no mess, no maintenance-just bolt in H&R Sway Bars and go!
$466
H&R Sway Bars
$466
Moved to the LOU
I am just now starting to order parts for my car and I will be getting the H&R sway bars for my '06 TL. Once I do I will let you all know what I think.
This may be a really dumb question but I notice that everyone replaces the sway bars on the TL but what about the strut bar?
RAR
we already have a pretty beefy strut bar. this hr strut bar may be one of the first I've seen designed for the 3g. lots of people talk about using greddy and what not, but those are accord strut bars.
Oderint dum metuant.
If I remember correctly, the H&R FSB is larger than the stock FSB (28mm vs. 25mm AT/27mm MT)...increasing the thickness of the FSB will increase understeer...not sure why you would want to do that. The H&R RSB is the same size as the CT RSB and will therefore have the same effect...failing to see how the additional $$ is justified.
Some people have replaced the strut bar; however, there is not currently a strut bar for the 3G TL...the people that replaced theirs used ones for 7G Accords. There are a couple of threads in the Photograph section about this...members who have done it are ACCURATEin and I want to say JDM5lugHatch, but I'm not sure.
Moved to the LOU
Well...if you spend a lot of time on these boards (and I do for one)...you'll find you're probably the first and only person to consider putting on the FSB. I haven't seen one other person do it yet due to the understeer issue. But to answer your other question, why would they sell them? Because they can and they make a ton of $$ selling RSBs for that price and FSBs for an unusually high price, and someone obviously buys them somewhere...lol. Doesn't mean it's the right product for this car though, or that it's a good idea, or I think you'd see a ton of us doing it by now, but hey, by all means spend the $$ and let us know what you think, you can be the first to let us know!
The bushings make some sense, yes, I upgraded mine to the aftermarket Energy Suspension ones for that reason over the rubber comptech ones, but it's not true that they will never need lubrication. Only if you don't want it to squeak ever! hehe....same is true of the aftermarket poly ones....want it completely 100% squeak free you grease them periodically. By the way, aftermarket poly ones cost about $15...so for the $100 sway bar and the $15 bushing kit I have the same bar as the H&R, there's no difference the bars themselves just the bushings. Actually, mine are better cause they have grease fittings so I can easily re-grease them at anytime.
I looked into replacing the stock bushings with the poly ones on the front sway bar by the way. Couldn't figure out how to get them off the car, then I received my service manual...ouch...you have to remove/drop the whole front aluminum sub-frame engine assembly to get it out...pretty big job for a product you don't really need to be honest.
If you want to get more bang for your buck do the RSB, suspension, then look into things like exhaust, racing pulley, CAI, grounding/voltage system, etc., don't waste all the $$ on the front SB, and unless you want to spend $300 more than you need to on the RSB get Comptech and aftermarket bushings.
Personally once I get to that point then I'm going to be spending some $$ on dynamatting the whole car then upgrading the stereo speakers, sub, and amp next.
Moved to the LOU
Another thought I had but am also aware that it is not at the same scale. I race on road and off road R/C cars and in our on road cars we have front and rear sway bars that can be attached depending on the track and the conditions. if I put on a .055 sway bar compared to a .063 in the front, yes it will make a drastic difference in how the car dives into a corner and comes out of a corner but on a 3,500lb car is 1mm going to create that much understeer under normal driving conditions? I'm not saying I am correct but it seems hard to believe that a 28mm FSB is going to be that much different than a 27mm FSB. Just my
Technically, it's 0.8 difference (27.2 vs. 28)...you're right, I doubt you'll notice anything with that. Not sure about the 2.6mm increase the H&R is over the AT FSB, but if you do feel anything, it won't be good. So if you're not going to feel anything or if you do feel something that is bad, why spend the money for it?
Moved to the LOU
I'm not going forward with the FSB mod I was just throwing the question out there about the .08mm difference. I'll keep you all posted on what I think about the H&R RSB though. Should arrive later this week.
RAR
Shift_faster
Originally Posted by leedogg
Just be glad the TL came with such a beefy FSB. Too bad the RSB in the MT wasnt standard across all models. Out of curiosity, has anybody looked into buying the MT rsb?
I still have my MT rsb, but I am holding on to all my stock parts...
By the way, gqchicago - You said pretty much everything I wanted to say regarding the front sway bar and the bushings.
Moved to the LOU
I'm doing the H&R for 3 reasons.
1. They make great products.
2. Bushings never have to be greased.
3. No one else has it yet. Atleast not that I have seen.
I agree wit the BMW post though. My co-worker just bought an '06 3 series and he paid a shit ton for it. Interior is so dated and the engine is smaller.
Shift_faster
However, I am happy with the CT and the only adjustment I would make is to change the bushings (I don't think I will purchase the H&R just for that difference).
Doctor Sarcasm
I want to start by saying that I just ordered the H&R RSB and that at this time I will not be purchasing the FSB.
Theoretically the Energy Suspension ones never need greasing too....made of the same materials as H&R....yet oddly enough they come with grease..so why not do it?
The H&R claim of being never needed greasing I bet comes from the Marketing Dept at H&R! LOL...
I doubt my ESP ones would squeak or thump at all to be honest but it's so darn easy to do it when you're installing why not do it....and for sure it's going to make sure it never happens.
Coming from the boating world it made a lot of sense to me that by filling the gaps / spaces in any bushing with grease rather than where water / moisture can get in there..freeze / etc over time...it's going to just be less problematic. Also debris / dirt / etc can get into any fitting like that that isn't greased. I have a marine propeller on the sailboat we grease every fall and the water and dirt comes squirting out before we winterize..that way the expensive gears inside of it don't freeze up over the winter.
What I'm still interested in doing if anyone ever figures it out is replacing more suspension components in the TL with the upgraded ESP ones. The end links for instance that connect to the RSB...look to be very easy to change out having done the a-spec kit and RSB...we just need to figure out the correct sizes or whether their product will work.
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
