HP Evo
HP Evo
Has anyone put an HP Evo wheel on the TL? .. I have seen an Accord here in town with them on and it looked good .. I tried a search but the words are too short.
I do my own work.
not sure, first you should see what the bolt pattern is on the wheels. If the bolt pattern on the Accord is the same as the TL, then you're halfway there. The second thing you'd need to check is the offset of the wheel so as not to throw off your suspension and handling characteristics and ultimately fitment. There are more knowledgable folks on the board. A good tire shop should be able to look up the bolt pattern and offsets for the Accord and TL.
The TL and the accord V6 both have 5 x 114.3 bolt pattern and the offset difference is 2 mm which is .078" which pushes the wheel out and away from the hub by .078" . If at all it may effect the camber and this, if the camber is adjustable shouldn't be an issue.
I guess the question still remains .. has anyone put them on a TL and if so .. pix please.
A.K.A Comptechtype-S!!
They should work fine on a automatic TL. The largest offset the wheels come in is a 40 (which should clear the brake calipers on the auto). I tries the HP's but they wouldnt clear the 6spd's calipers. I ended up getting the AZA Z2's (which look exactly the same).
Here are pics of the HP EVO on an SSM TL in this post:
https://acurazine.com/forums/ramblings-12/who-likes-my-avatar-%2Anws%2A-112131/
