How much torque is too much ??
Old Sep 19, 2005 | 06:50 AM
Whitesnake's Avatar
Question How much torque is too much ??
Hello all,
I just got my tires rotated and balanced. I was wondering if too much torque is too much?.. in the manual it says I think 8x something. The garage I took it to did 100LBS.. IS that ok?
Old Sep 19, 2005 | 08:36 AM
TLVR's Avatar
I think the specified maximum torque for our TL is 80-85 lbs. Yes, going over could lead to problems like warped brake rotors. Sometimes the techs will use torque sticks which are limiting the torque. They are different colors so make sure the correct ones are used. Rarely are torque wrenches used nowadays. Go back and have it fixed NOW. Good luck!
Old Sep 19, 2005 | 09:11 AM
chill_dog's Avatar
Oderint dum metuant.
But a torque wrench and rotate your own tires. It's not hard, it saves a good bit of money, and you know it's done right.
Old Sep 19, 2005 | 07:36 PM
Adobeman's Avatar
The DVD-A Script Guy
Since I have separate rims for snow tires I don't ever let the tire guys ever mount a rim to the car. If I need tires I drop off the rims (that aren't on the car) and then pick them up later once the new tires are on.
One set of warped rotors, stripped lugs, or lugs you can't get off when you flat is all the lesson you will need.
Old Sep 20, 2005 | 02:54 AM
rstark's Avatar
SSM 6MT
Let me add that the cheap "beam" type of torque wrench will do for the tires. Very inexpensive solution, but good insurance.
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Skirmich
Oct 1, 2015 12:59 PM
hpfiend
Sep 27, 2015 06:59 AM
Rcelestino93
Sep 23, 2015 10:01 PM
