Help with staggered set-up...
Just wondering if you guys could help a noob out regarding staggered set up.
I recently just purchased rims/tires: (in storage at the moment)
19 x 8.5 fronts
19 x 9.5 rears
Falken F452 tires **245/35/19 all around**
Upon reading up/searchin on past posts regarding "staggered set up", a member mentioned that "as long as it's a non-directional tire, it could be rotated...is this true? Does anyone know if the falken F452's are non-directional? If so (if it is non-directional), i can rotate the REAR driver rim/tire to the REAR passenger rim/tire...is this correct?
If anyone could chime in, i'd appreciate the help...but upon reading past posts, it seems like there is no way we could rotate tires unless they are taken off the rim = which would cost a grip!
TIA!
19 x 8.5 fronts
19 x 9.5 rears
TIA!
Registered Offender
Falken 452's are directional, meaning they rotate only one direction. You will not be able to rotate your wheels. The only way to rotate tires would be to remove all 4 tires from the rims and re-mount them in the opposite direction.
nuldabz
09-03-2015 05:49 PM
ptballer
09-16-2006 01:16 PM
