HElp with rolling fender....
Old Jan 27, 2002 | 10:32 PM
wiggingboy's Avatar
Does anyone in houston know a place where i can get my fender roll at? i just got some rims for my car and it rubbing pretty badd..
I'm rolling on VOlk Av3 with 235 40 18.
Yes i know the tires is what causing it to rub but i still wanna get my fender roll anyways. Thanks...
Old Jan 28, 2002 | 03:31 AM
Lawaia's Avatar
Moderator Alumnus
Just use a baseball bat and do it yourself. It'll save you some $$$'s.
Old Jan 28, 2002 | 07:07 AM
NSXNEXT's Avatar
What's the offset on the AV3s?
Old Jan 28, 2002 | 04:53 PM
valuetl's Avatar
I hope they are 7.5" wide wheels. The highest offset for 8" is 46MM. 7.5" run up to 49MM. Your other choices are worse 43 and 44MM.
Old Jan 28, 2002 | 09:01 PM
StanMan's Avatar
i posted in the main tl forum...check there.
Old Jan 28, 2002 | 10:27 PM
what are you talking about? higher offset means it moves into the center for the car more, and lower offset moves towards the outside of the car. therefore, you would want a higher offset to clear the fender.
Old Jan 28, 2002 | 11:04 PM
TLluver's Avatar
Thats what he said, "I hope they are 7.5" wide wheels. The highest offset for 8" is 46MM. 7.5" run up to 49MM". He is saying 49 is better...you should really read before you post.
Old Jan 29, 2002 | 12:20 AM
StanMan's Avatar
actually offset ranges can vary greatly, regardless of widths, depending on the manufacturer...
as for offsets, higher can mean farther from the center and lower can mean closer to the center. remember there are POSITIVE and NEGATIVE offset values (as well as ZERO offset). since we have fwd cars, i hope most people understand that we are talking about POSITIVE offsets...hence the + sign in front of the value.
Old Jan 29, 2002 | 12:21 AM
wiggingboy's Avatar
OK guys...i just roll my fender and cut the plastic tab off. 90% of the rubbing stop. It just rub when i hit a big ass dip.. And about the offset.. i have idea what it is... It came off of a late moderl prelude to a maxima and then to me...
Old Jan 29, 2002 | 12:23 AM
StanMan's Avatar
again, remove the wheel and examine the back of the wheel face for the value.
sometimes, the rim cylinder will still have the spec sticker... some remove them for aesthetics, but i leave mine in place to certify the specs in case i sell the wheels.
Old Jan 29, 2002 | 01:51 PM
wiggingboy's Avatar
i took the wheels off today....And all i saw was 18x j i dunno what the j means. there was no number next to the 18. and all the labels was in jap. so i cant read it. Oh well...i guess i'll just wear these tires out and buy new one. Even tho they are mich. pilot sports.
DerrickW
Nov 15, 2015 05:52 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
