Help! I can't take out the rear shocks
9th Gear
Hi everybody, this is my first thread and I must say this forum ROCKS! Anyway, I'm trying to install HT-Spec coilovers but I'm having trouble taking out the rear shocks. I took everything off as instructed but having trouble taking off the nut on the endlinks to slide out the shocks. Any advice is appreciated.
BTW, how can I insert pics? Sorry, I'm a newbie at this.
Jokerman
Hopefully your endlink isnt corroded, I tried putting an allen key in mine to tighten the bolt and now it is just a round hole, so when i have the chance I will have to cut mine off and replace them.
AZ Track Whore
don't mess with the endlinks, they are a pain in the ass and will make this more of a hassle than it is.
The upper side of the endlink attaches to a bracket, and this bracket is held to the spindle/hub by a single 14mm bolt. Remove that bolt and you can make all the room you need to get it out.
9th Gear
Thanks guys. Yes, i removed the bolt and loosened out the bracket but im still having problems taking out the shock. i cant create enough room. btw, i did try to take off the endlink but the threads are rusted so when i kept spinning the nut, the other end started to turn. i hope i didnt f up the endlink. I just couldnt make enough room to take em out last night. Maybe i just gotta mess with it some more...
I had trouble at first with the rears too.
Your best bet is to read this thread:
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/diy-ht-spec-coilver-install-dummies-any-other-suspension-3g-garage-d-091-a-816065/
It's the same method that vill0169 suggested.
Remove the bracket.
Then put a jack under the arm and raise it to create a gap and just twist it out!
I didn't even BOTHER with the endlinks. I saw them with so much rust and stuff I said EFF it and just removed the bracket.
Then I did the second side in like an hour lol it was so easy once you learn the tricks.
Remove the bracket.
BoricuaTL
04-08-2016 01:08 PM
09-17-2015 09:01 PM
