Hellaflush Skunk 2 UCA pics
Old 07-17-2012, 02:38 PM
speedy4ever's Avatar
can someone with skunk 2 uca's with the hellaflush option please post pics of where the modification is made. i need to get more camber out of my skunks. is the ball joint just flipped? any help will be appreciated thanks...
Old 07-18-2012, 06:34 PM
alrite, since i couldnt find any information on how to do this, i decided to attempt it on my own. i decided to flip the ball joint and trim off some material on the uca in order to do so. this was a spur of the moment thing and all i had was my cell phone as a camara, sorry for the crappy pics but they give the general idea.
i hope this helps someone out
i used the top ball joint bracket as a template of how much a wanted to trim off.
i used a sharpie and mark the amount to be trimmed.
maxed out without the modification.
ball joint flipped and uca needs to be trimmed to allow fitment.
uca with portion trimmed off. i trimmed off more than was needed to fit the ball joint, but it will allow even more camber if i ever need it.
ball joint flipped and mounted, notice the spare room to slide the ball joint back further if needed when doing the alignment.
sinaa (07-30-2012)
Old 07-18-2012, 06:37 PM
ill bolt them down tonite, hopefully the upper ball joint bracket doesn't interfere with clearance.
Old 07-18-2012, 06:44 PM
Italiano's Avatar
yea if u install them how they come its like 1.2 negative....if u flip it u can get the negative 3 degrees camber....im runnin these
Old 07-19-2012, 10:07 AM
2014 Jeep SRT
ebelp's Avatar
Received 1,615 Likes on 1,030 Posts
Nice work, but it scares me that your cut is a little uneven on the right side there. Hopefully that won't affect the structural integrity of the UCA.
Old 07-20-2012, 04:37 PM
yea i got a little trigger happy on that side, but there bolted on now and no problems. only regret is that i shouldve cut deeper down cause i might need more camber.
Old 07-28-2012, 01:08 AM
nhb04tl's Avatar
Old 07-30-2012, 05:15 PM
9th Gear
sinaa's Avatar
oh man you are a life saver lol. i was about to put up my brand new upper arms for sale in order to buy the hellaflush ones. did you get it aligned? im wondering how much negative camber you were able to achieve with this mod.
im running a +9 offset on 18x9.5 and 215/40/18 and i have rolled and pulled but its still not enough. skunk2 upper arms are maxed out too. so i think im going to give this a try.
Old 07-31-2012, 02:09 PM
i havent aligned the car yet. its a hassle getting it on the alignment rack and havent had a chance to do it at work, i recently rolled and pulled my front fenders but im still rubbing were the fender meets the bumper. either ill try and add more camber or ill trim off some metal off the fender, either way ill align it this thursday and keep u posted.
Old 08-04-2012, 11:08 AM
this are the readings before the alignment. thats negative camber max'd out in the front with the modified skunks.
after setting the toe to zero, i ended up with
front left -3.5
front right -3.6
rear left -5.3
rear right -5.4
Old 08-08-2012, 01:09 PM
rhafikjaan's Avatar
dont you get like -2 up front from the drop anyways? i have -2.3 up front with no camber kit... adding the uca modified would i get -5.3?
Old 08-09-2012, 04:44 PM
yea i think u get more camber with the stock upper control arms than the non modified skunks. u might be able to get more than 5 degrees neg camber off the skunks, but you would have to trim off a little bit more than i did.
Old 08-10-2012, 02:34 PM
kibbles906's Avatar
might have to do this soon if rolling the front doenst stop the rubbing!
Old 08-19-2012, 11:51 AM
rhafikjaan's Avatar
do you still rub? i just got my camber kit.. going to flip the ball joint and thinking about taking it to a shop that works with metal to get them evenly trimmed
Old 08-19-2012, 09:11 PM
sourial84's Avatar
do you have b4 and after shot of the car with this mod
Old 09-17-2013, 04:38 PM
styles109's Avatar
Before and after pics pleaseee!
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Hellaflush Skunk 2 UCA pics
