h&r springs vs tein springs
i-luv-rice
hey acurazine members. new to the acurazine community. just bought a :ecstatic 3rd gen type-s. was wondering if it already wasn't a thread but interested on lowering the car, not sure bet h&r or teins. read up on all the forums as far as proper way of doing it, ride height, shocks and so on. just wanted to know who's using what.
AZ Community Team
Received 7,771 Likes
+1 for H&R here.
Haven't run the Tein, but lots of people do, so there must be something to 'em.
Tien, H&R and Eibach all seem popular and you don't hear too many complaints about any of them.
iScrape going into
Originally Posted by padthai81
so i guess im gettin the h&r race springs since the drop is more lower then the sport ones.
AZ Community Team
Originally Posted by Distorted Reality
If you aren't planning on replacing the struts, I'd consider it. Only because those springs with that drop they give can premature wear the stock struts out faster. Easier to replace it all at once then have to go back later and replace the struts.
I agree. Based on what I've read there is *risk* of premature shock wear with the Sports (or *any* moderate lowering spring). With the Race springs it's virtually guaranteed.
Also check around the forum for users with Race Springs. In general "Race" spings provide a pretty rough ride unless the roads are pretty smooth. Can't speak to H&R specifically, but you should ask around. There was a thread on it a few days ago.
i-luv-rice
ifirahse, so as far as h&r race springs and tein s.tech's. what you reccommend. i know you have the teins but have you had any problems, concerns, or regrets. going by your pics i don't see any complaints
SlammedOnKonis
i highly recommend getting koni yellow struts as well at the same time you get the springs though.
i-luv-rice
well getting new struts are on my list. considering the fact my girlfriend is the manager at the acura dealership ill probably end up getting the a-spec struts with the tein s.techs for mad cheap. what you think
SlammedOnKonis
Former Sponsor
Originally Posted by eluzion
Do the rear springs tend to sag on Tiens?
I think you need to be a little more specific as I interpret this a couple different ways.
Do the rear springs sag? Sagging is a failure in quality of the spring where the coils fail to hold the weight of the car. Usually this is evidenced by more and more lowering over time. No Tein springs don't sag. They have a 1 year warrantee against sagging.
Do Tein springs lower the front of the car less than the rear making it look like the rear is sagging? No, Tein spring usually lower so that the tire gaps are the same front to rear. This usually means more lowering in the front than the rear, giving the car an aesthetic rake.
Former Sponsor
Originally Posted by BrickCityCoolie
which would be a better buy for a better ride? the h&r sport springs,h&r racing spring spring or the tein s-tech?
Not 100% sure on this one.
Htech and H&R sports are going to be similar, and Stech and H&R are going to be similar...
The more low = the more firm.
I also just put a set of progress in a 3G yesterday and the ride/drop is pretty favorable there as well.
Marcus
i just had some s-tech dropped 2 days ago. i like it! the rear is 0.1inch lower than front. but overall the TL looks a lot better!
post #103, i have pics there: https://acurazine.com/forums/showthr...=184569&page=3
i ordered from MrHeelToe, thanks!
I can't decide between the H&R Sports and Tein S-Tech. They both claim a similar drop but in every picture I see the S-Techs seem much lower.
SlammedOnKonis
Originally Posted by ssmtl2nv
FORGET ABOUT KONI'S, I sold my konis for tein ss coilovers, the ride on ss's is a million times better than shocks and struts......
Actually I take that back. Some pictures the Tien S-Techs look fine, in others it looks like the rear is just a hair lower. I guess it really depends on the whether or not they have a dead body in the trunk.
Either way, what I have noticed is the S-Techs sit slightly lower than the H&R Sports (based on pictures), but again whatever wheels you have will really make a difference (as far as how much wheel gap there is).
This is ililililiililil's car (hope you don't mind me using your picture) on H&R Sports and stock shocks (afaik). I think it's the perfect drop for a daily driver. Not too low, just right.
EDIT: His is the car on the right (right as in looking at the picture)
so basically there almost the same i think i would go with the h & r i mean there both the same price i just got a 05 tl non type-s and would like to drop it for now on spring until i get the koni yellows so i wanted to do research before i buy thanks for your help i hope i made the right decision.but being on the site for 3 days now i came across the koni yellow with h & r or the s - tech and i dont want to mess up the suspension so i guess the koni yellows would be the one to get the job done of riding low but having the same stock ride correct me if i am wrong?
Yeah they're really close in drop but the TEINs are slightly lower from what I've seen. Any drop is going to make your ride slightly more aggressive but with good shocks like Koni Yellows, it will help maintain that stock/comfortable ride. Also, if I'm not mistaken, the Koni Yellows have different perch settings for the springs so you can +/- the ride height a little bit.
Well I just canceled my order on the H&R Sports. I really want something slightly lower. I currently have the Eibach Pro Kit but the rear is lower than the front which I can't stand.
I might just bite the bullet and go with full coilovers since I'm not finding any springs that give me the drop I want on stock shocks. If I'm gonna go with Koni Yellows + springs, might as well go full coilovers I suppose.
ifirahse - Those Koni Yellows have adjustable perches for the height, yeah? If so, are you running them on the lowest?
Originally Posted by ifirahse
Yeah they're adjustable...
and yeah they're on the lowest.
How do the adjustments work? From what I understand there's five different perch settings. Is the 3rd (middle perch) considered stock? How much lower is each perch?
Tl-s
Hmmm, obviously all these applications will vary depending on the vehicle used. The TL-S is already much stiffer OEM so how would you determine which application to replace TL-S suspensions?
i just ordered these H&R Street Performance Coil-Overs
http://www.acuratlparts.com/product.php?pid=4
how low should and could i go? i have 18's
comments, suggestions, opinions
MrHeelToe
Former Sponsor
What about the performance? I got the Koni's over the tein ss because I was told that the konis are more performance oriented rather than comfort.
Performance orietented people say that because they tend to be more track people and they in general have a bias against popular street items, such as Teins. Seen it repeatedly on honda-tech.
Konis are claimed to be better because wider dampening adjustment range. What people fail to realize is that Konis are replacement shocks designed to work with a wide variety of springs. Tein coilovers come with springs so the shocks are designed to work with those. The Tein adjustment allows for fine tuning while the Koni adjustment allows for flexibility in spring choice. That's the biggest difference I can see.
For quality both are sure bets.
Marcus
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
