got my alignment done the other day
Stuck in Vegas.
i got a hook up at a shop here, my buddy did my alignment
it was pretty bad, not horrible.. but noticable..
here's my printout ..
i know i need to get my rf caster fixed.. but besides that .. what do you think ..
![](http://i22.photobucket.com/albums/b310/emoflip/UA6/CCF07242008_00000.jpg)
lol ignore my buddy's signature and such in the upper left corner
Stuck in Vegas.
Originally Posted by JCL622
i'll try to dig up one of my alignment sheets for you to compare.
on a side note; your friend's name IS Phillipino?
but he had trouble spelling FILIPINO haha
you may have something bent in the RF suspension- control arm or something
The caster is an imaginary vertical line and the tires relation to it- there is NO adjustment for it and if its off- that means something bad is wrong!!!
Your camber and toe are fine- it should turn into the corners nicely too with the negative camber
Thats low enough neg camber number that no funky tire wear will occur
Stuck in Vegas.
last year this time i got hit by a pole that fell off a truck.. yes the pole hit me! and it fucked up my whole front end along with my complete right side suspension, subframe and motor mounts.. plus a lot more ..
are you suggesting that a control arm is still bent?
I cant diagnose from here- perhaps if you moved the modem closer to the car....
SOMETHING is bent- I cant say what- but the alignment shop should be able to!
All they need to do is look and see whats not the same as the other side.
Could be a few things
Stuck in Vegas.
did you lower it after you got it back- and never did the alignment?
- or is this how they gave it back to you? with those numbers?
Few acura dealerships do crash repair in -house- , being easier to subcontract out to a shop that specializes in that. If the job was done wrong or incomplete, they have a liability- and if your insurance paid for it they can always amend the claim and add whatever.
Of course that would depend if they did an alignment at the time of repair- should have, and seen the caster prob.
If all was well when car was returned- you took a road hit since then. Welcome to life on Earth
SidhuSaaB
05-30-2020 12:40 AM
