Go with 10" or 10.5" wheels in rears?
Old 11-27-2012, 03:04 PM
blah
Vietnastee's Avatar
Should I go with option A) 19x10+23 on 235/35 or option B) 19x10.5+29 with a 245/35 in the rears?
My main concern is with the 10.5 touching the strut if I camber it too much to make it flush. I remember a member saying he could only dial in -2 degrees in the rear and sometimes it would hit the strut already.
Any body have an idea what's the max camber I can run without touching the strut on 10.5 setup?
I know I can camber the 10s more without a problem.
Old 11-27-2012, 03:50 PM
HE>i
05_NBP_TL's Avatar
I have seen a 10 +42 with a 265/30 tire in the rear before, so with a +29 you have plenty of room for camber.
search for member Anakalia. She is a chapter leader in San Antonio.
Also found this CLICK HERE
Old 11-27-2012, 04:13 PM
k1x
rocking my vs-sexx!!!
k1x's Avatar
i have a 10.5+29 rears with 265/30 camber is -3.5..im not hitting the strut just rubbing my fenders are shaved in the rears...i think if you go with 245/35 you will be safe thats my next tire setup in the rears.im almost maxed out on tein sa..3 threads left.
goodluck bro hope this helps.
what wheels are you getting??
Vietnastee (11-30-2012)
Old 11-27-2012, 04:25 PM
blah
Vietnastee's Avatar
Thank you everyone. I'm not concerned with the rim hitting or rubbing the fender. Camber can fix that if the inner wheel clearance allows it.
I'm still debating between the vs-xx and some other work wheels I have in mind.
Old 11-28-2012, 02:12 PM
blah
Vietnastee's Avatar
k1x, pm sent!
Old 11-28-2012, 02:15 PM
Received 16,263 Likes on 11,973 Posts
That looks exactly like Andrea's car.
except its not.
Im thinking she bought those CCWs from him!
Old 11-28-2012, 02:47 PM
Desert Life Sucks!!
sauceja's Avatar
15x12 reversed wires would look pimp on a TL
Old 11-28-2012, 02:48 PM
Bobby Digital's Avatar
10.5...do it!
Old 11-28-2012, 03:49 PM
blah
Vietnastee's Avatar
Now should i go 19x9.5+28 or 19x9.5+23 fronts?
Old 11-28-2012, 06:10 PM
Desert Life Sucks!!
sauceja's Avatar
What do you want to run on the fronts?? Its not our car.
But I would say +23 with 15mm spacers. That way you can laugh at the HellaFlush.
I like the KindaFlush look personally.
Old 11-28-2012, 06:36 PM
HE>i
05_NBP_TL's Avatar
Go with 19x9.5 +23 with 225-35 tires. Basically the same as what I have (19x9.5 +22)
Cjlgarage (12-07-2013)
Old 11-28-2012, 06:52 PM
blah
Vietnastee's Avatar
^ Does that sit flush or does it poke?
Old 11-28-2012, 06:54 PM
blah
Vietnastee's Avatar
What do you guys think of these specs? Good enough to be kinda flush?
Fronts: 19x9.5 +22 with 225/35
Rears: 19x10.0 +20 with 235/35
Old 11-28-2012, 09:12 PM
Poke please!!!
Old 11-29-2012, 04:44 PM
HE>i
05_NBP_TL's Avatar
Yes, you will be flush!
Originally Posted by Bobby Digital
Poke please!!!
Mine sits flush. Thats what camber is for
Old 11-29-2012, 04:57 PM
blah
Vietnastee's Avatar
Thank you everyone for your help.
I'll come back and post some pics when the wheels arrive.
Old 11-29-2012, 05:11 PM
HE>i
05_NBP_TL's Avatar
^Sounds good!
Here is my setup. 19x9.5 +22 all around w/ 225/35 tires. -2 camber front and -2.5 camber rear
Old 11-29-2012, 05:43 PM
blah
Vietnastee's Avatar
Your car looks like my car. Great taste
But your stance is muchhhhhh better than mine.
Old 11-29-2012, 06:11 PM
Registered Member
The Machine's Avatar
05_NBP_TL, any rubbing with your setup? Hard to tell but I think your rims are the varrsteon es1.1.2. I am getting the es1.1.1 with 9.5 +30 front and 10.5 rear +30. 225 up front and 235 in the rear. I have a camber kit in the rear so I'm hoping I don't have to go too negative to get this to fit without rubbing since I went +30 and not +22. Thoughts?
Old 11-29-2012, 06:48 PM
pitorican's Avatar
05_NBP_TL what camber kit are u running..i putting on varrstoen3.3.2 19x9.5's with 225/25/19 on my 07 DWP TYPE S and was wondering do i need to invest in a camber kit.. i really dont wanna eat up tires
Old 11-29-2012, 06:58 PM
Registered Member
Depeneds on offset and how low you want to go.
Old 11-29-2012, 07:04 PM
pitorican's Avatar
Pretty much the same stance as the pic of the black tl... im gonna run a +22 offset
Old 11-29-2012, 07:08 PM
pitorican's Avatar
Sorry i messed up typing on my first post im gonna be running a 225/35/19
Old 11-29-2012, 07:56 PM
Registered Member
He is pretty low, I'm guessing in the 2.5" drop range, so I'm going to say yes, do yourself a favor and get a camber kit.
Old 11-29-2012, 07:59 PM
HE>i
05_NBP_TL's Avatar
Only the front rubs when turning while on an incline. not while driving straioght. I just go slow pulling into parking lots with dips or inclines. All other driving conditions are fine.
I am running ingalls rear camber kits and Skunk2 camber arms up front. I would lower your car and put the wheels on to see if you need to adjust your camber any. Alot of members are getting away with natural camber up front and adding a rear camber kit. if you are going as low as I am I would recommend camber kits front/rear.
I went ahead and installed everything at once (wheels, coils, camber kits) then tweaked my fitment from there. Let me know if you need anything else
Old 11-29-2012, 08:04 PM
HE>i
05_NBP_TL's Avatar
I never measured the factory height. I just installed and lowered to where I wanted it. Took a couple days of adjusting, driving, staring, then adjusting some more to decide where I wanted to keep it set at.
Im sitting around 24" ground to fender clearance at all four corners.
The Machine (11-29-2012)
Old 11-29-2012, 08:18 PM
Registered Member
I think factory height is around 26.5 so I was spot on guessing your drop Do you ever have adult passengers in the back? At that rude hit and as flush as you are do you rub when a passenger is back there?
Old 11-29-2012, 08:47 PM
HE>i
05_NBP_TL's Avatar
NOt often, have had my son and wife back there (32lbs + 117lbs). Just recent built my infinite baffle audio setup with one 12 and still have not hit at all in the rear. It is a close fitment and I still get nervous sometimes, but I have never hit the fender (rears are rolled and pulled slightly).
Its close...
Old 11-29-2012, 08:51 PM
WOT in the new ATLP V2s!
Izzy-Type-S's Avatar
Do you know what wheels these are? I have a type s soon to get wheels.
Old 11-29-2012, 08:56 PM
HE>i
05_NBP_TL's Avatar
^CCW Sp16R
CLICK HERE
Old 11-30-2012, 05:24 AM
Registered Member
Its close...
Yeah, wow, that is pretty close. I'd love to see a Go-Pro video with it mounted looking at the rear wheels while driving to see how close the rim comes to hitting the fender going over bumps, etc. Glad to hear it doesn't rub though!
Any full shots of the car?
Old 11-30-2012, 06:00 AM
HE>i
05_NBP_TL's Avatar
^ I have pulled onto an incline/ditch to check the clearance of the wheel. The rim cambers just enough to clear the fender. I can get a picture of it tucking the rim later on for you.
Sorry, no GoPro ( I have a Nikon D7000 that does HD video but I dont have a rig setup to do videos of rolling shots).
The Machine (11-30-2012)
Old 11-30-2012, 08:52 AM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
Machine, 05 NBP TL and i are running very similar specs. i can shoot a gorpro video for you later on today and upload it soon, if you want.
The following 2 users liked this post by SharksBreath:
05_NBP_TL (11-30-2012), The Machine (11-30-2012)
Old 11-30-2012, 02:22 PM
Registered Member
Yeah no doubt! Would love to see video of either setup.
Old 12-01-2012, 08:45 PM
HE>i
05_NBP_TL's Avatar
Pitorican and The Machine, here you go with more pics. No vids for me though .
Note: These pics are on an incline to try to imitate what the wheel looks like when it cambers inwards while driving.
Old 12-01-2012, 09:45 PM
^CCW Sp16R
CLICK HERE
thanks
Old 12-01-2012, 09:46 PM
Registered Member
Hot damn that is close! If camber was set to -3 in the rear would that give you more clearance when the wheel cambered in going over and incline or bumps?
And full pics of car, now!
Old 12-13-2012, 10:15 PM
UA6LIN916's Avatar
im running almost that exact set up except front +20 only difference.. sits flush i posted in WHEEL/TIRE section if you want to see pic. front sits perfect, rear i rolled fenders and camber kit
Vietnastee (12-14-2012)
Old 12-14-2012, 01:48 AM
blah
Vietnastee's Avatar
Car looks good with the Ordens
Old 12-14-2012, 02:08 AM
UA6LIN916's Avatar
thanks.. ordering my lip kit this weekend, and accord fogs
Quick Reply: Go with 10" or 10.5" wheels in rears?
