Function and form questions
I just purchased a set of function and form type 1 coilovers and i wanted to if would have any issues installing them on my 06 TL. Hoping to receive any tips if there are other things that i would have to change on the suspension.
i seeeee. how much did you get them for?
nvm just searched ebay and found these
http://cgi.ebay.com/ebaymotors/04-08...Q5fAccessories
hmm they look the same as these
http://www.heeltoeauto.com/HT-Spec-C...-pr-65757.html
you shouldn't have any problem installing it... theres a DIY around here somewhere
oh here you go
HT-SPEC DIY -- https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/diy-ht-spec-coilver-install-dummies-any-other-suspension-3g-garage-d-091-a-816065/
oh here you go
06 ThugLuv
if u completly do one side, ur sway bar will be sitting higher then ur stock side that u havnt done yet. and when u go the disconnect the sway bar on the other side it will suck balls. basicaly.
other then that its super easy.
n i got the ingalls rear chamber. also easy install.
good luck homie
06 ThugLuv
Chapter Leader (Central Florida)
1fatcrxnem1
22
06-01-2018 01:23 AM
