FUBARed, need some help with rear sway bar.
Team Anthracite Webmaster
Hi Guys.
I installed the comptech rear sway bar, along with most of you, back in 2005. Everything was fine. Recently there was some squeaking noises so I bought some Energy Suspension bushing grease (I had the new energy suspension bushings) and added a dab of grease. Things were good for a few months.
I'm not sure WHEN this happened, but today I noticed some bad-sounding thumps. I lift up the car and see this:
![](http://img387.imageshack.us/img387/2048/pict0022lt7.th.jpg)
![](http://img387.imageshack.us/images/thpix.gif)
as you can see, the place where the bar/bushing is attached to the frame has completely sheared off of the car. I'm not sure how this happened, maybe I over tightened? Didn't use a torque wrench but I didn't exactly try very hard to over tighten.
Anyone know if this is even replacable by the dealer without some significant frame work? Anyone else run into this issue?
Thanks all, this has just been a horrible week.
found this over on the TSX forums. looks like using the energy suspension bushings and comptech bar put too much stress on the rear frame components.
https://acurazine.com/forums/1g-tsx-tires-wheels-suspension-130/aaargh-chassis-bracket-rsb-busted-off-676363/
yikes I just installed my comptech RSB on stock suspension... used the supplied rubber bushings and added some lithium grease. hopefully i don't run into this problem. good luck and let us know where you get it fixed.
thats another f'ed up rear subframe due to an RSB, theres another thread on this in problems and fixes.
Heres my question. Are you guys, that ripping the sway bar bushings out of the rear subframe, running the stock suspension? I would think that with the bigger/ stiffer swaybar you would need to run a stiffer suspension. If not, the amount of flex that the suspension is trying to do is transfering to the mount and ripping them out of the subframe. I have heard of the mounts for the swaybar links ripping off because the suspension was to weak for a thick ass swaybar.
Head a da Family
I have the Comptech sway bar and had a similar problem earlier this year. Turned out the rear sway bar end links needed to be replaced. Thicker stabilizer bars put more strain on them.
Hi Guys.
Thanks all, this has just been a horrible week.![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Also the universal bushings are wider then the ones comptech sent and it sits right next to where the curve of the bar begins on both sides so there is little to no straight bar and after looking at my stock bar and where the bracket mounts there is more straight bar on both sides. So my assumption is there needs to be room for some side to side movement and after looking around the web the bracket separtion seems to be happening with people who are using the universal bushings with the comptech bar. I have the non-grease fitting bushings by the way and only have had the bar on for 3 weeks. I am no engineer and this is just my observation in hopes someone could chime in to correct me or add more information.
i'm not positive if they didn't line up that well, as I did the install quite a long time ago- however I don't think it was that bad.
My options now are to get this welded up or to get a new subframe. I'm leaning towards the 2nd, and putting the stock bar back. I'm not sure how well aftermarket welds will hold up in the long run, and I'm not sure if i really want this bar anymore!
RavynX (03-26-2013)
BoricuaTL
04-08-2016 01:08 PM
MonkeyTrucker
09-21-2015 06:15 PM
