Front sway bar replacment
Hi All,
I need to replace driver side front sway bar. Dealer recommends to replace the both and ask for about $160 + tax. Where local repair shop ask for much cheaper amount. Is there any reason I should go with the dealer and also to replace both. I would appreciate any help and comments.
Thanks so much in advance.
I would definitely replace both sides, because they work off each other. If you were to replace the one it would be okay but ultimately you would wear the new one out faster because it would be doing the majority of the work. I wouldn't take it to the dealer for that price!!! $160 +tax?! that is ludicrous! There is no reason to take it to the dealer, unless you just prefer them. Personally I would do it myself, it's not complicated and it's around $30 for endlinks.
It will put more tension on the bar when conering, but that is what the bar is made for. Also if you decide to go with the Moog, you must definitely replace both sides.
We have a couple of vendors for OEM parts. One of the vendor sites is oemacuraparts.com I have personally bought from him, I believe his name is Tim. You can get MOOG parts from Oreilly Auto Parts, or eBay.
Thanks for the help. I appreciate it alot. I just placed the order through Tim. Thanks again. Going to use a local repair shop to install. Labor + parts will cost on $100. I saved closer to $90 thx.
Honestly after having to remove a set of rusted to hell end links I sort of wish I had just paid someone else to swear at the car for an hour. Its not hard if everything is still in good condition. The OEM endlinks are a bitch and a half to get off in bad condition because of the cheezy hex key you have to use to keep them from spinning. I eventually had to use a dremel to cut off one side.
takin care of Business in
Received 4,732 Likes
go with Moog and do it yourself....
Here is a trick I learned when i replaced my rear end links when installing my aspecs.
The hex key can stay in the tool box if he end link is rusted to shit.
Take a set of needle nose vice grips and clamp it down on the rubber in between the end link and sway bar. Then crank away.
Chances are the nut will seize before coming completely off. You then whip out the dremel and cut away at the bolt.
I just replaced my front end links a few weeks ago and did the same thing.
Strangely enough, the front end links were not rusted at all and came off pretty easily.
Just remember to tighten the bolts once the car is back on neutral ground. Dont tighten the nut while the car is jacked up.
btw...that hex key hole is useless.
asahrts
09-04-2015 05:55 PM
