Front Brake shims aftermarket pads
Hey guys quick question and some advice, Changing out the pads on the 04TL AUTO. again.
Using some Hawk Ceramic and had a question do you guys still use the Acura Shim kit that is installed with the OEM pads or will some anti-squeal work. Thanks
RS
RS
Use whatever came with the pads. If the pads don't come with shims, you don't need to (and shouldn't) add shims. Be sure to use a quality brake grease and grease the back of the pads, the retaining pins, and the spring clips where they touch the pins and pads.
asahrts
09-04-2015 05:55 PM
09-04-2015 08:03 AM
