Factory BBK
Since your spokes are straight up/down, and the stock OEM wheel offset is +45mm, that gives you 13mm of more space. You would just have to measure the thickness of the Brembo calipers compared to the stock non-Brembo calipers. If the Brembos are less than 13mm larger than the non-Brembos, your golden! However, those 13mm's might be erased depending on how much the size of your lip pushes in your spokes toward the calipers.
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
