Excelerate Performance: XLR8 Coilover Group Buy!!!
#41
Just let me back myself financially make sure im good with all bills, i will post up deposit no later than January 27th guys
#42
big bad bust
![Rave](https://acurazine.com/forums/images/smilies/trance.gif)
#43
Lol it'll probably take a little more than 20 bucks to help all you guys out. I was think a little more a long the lines of a mil or so hahha it'll never happen tho. I got no luck.
teckademics gtr (01-20-2012)
#52
Suav7 should have been 9..
1) TheMachine - deposit paid
2) Callahan - depost paid
3) teckademics gtr-deposit paid!
4) ChiCity - deposit paid
5) anthracitecl - Deposit paid!!!
6) VicTL06 - Deposit pending...
7) Primus- Deposit paid !!!
8)TripAcez- Deposit Pending!
9)Suav7 - Deposit Paid
10)eyeTn3rd - Deposit Paid!
#58
Registered Member
Yeah I am debating a camber kit also. I was going to probably do about 1.75 - 2 inch drop, and I can say FIRMLY that I will NOT drop it anymore than 2 inches. If negative camber isn't going to be horrible I may save myself some money and not buy one for the rear. Comments, suggestions?
#61
No, I'm saying when u lower 2" or less you shouldn't need a chambering kit, anything more than 2" you will need a kit. That is if you don't want to buy tires all the time. Either way get a alinement and see how far out you are and go from there.
TripAcez (01-21-2012)
#67
#70
I think the answer is going to be like that of most other manufacturers: Every coilover system has the capability to seize, depending on your environment. West coasters have less of a chance of seizing due to the lack of salt seen on the roads. East coasters see much more inclement weather, accelerating the possibility of seizing.
I guess my question was more, what are the threaded bodies coated with? And I know that the new Tein Basis coilovers have adapted a new system in which it is much easier to raise the car. I always had trouble raising the car to a certain level as the spring compression prevented me from doing so. I'd like the comfort of raising my car without all of my strength for the winter, and the ability to lower (much easier than raising, of course) during the summer and spring.
TripAcez (01-22-2012)
#71
And the ride height isn't adjusted by lowering or raising the coil spring, like the TEIN coilovers. It is done by lowering or raising the bottom part of the suspension. You pre-load the spring and then make all ride height adjustments by spinning the lower shock housing. Look at the picture below:
![](http://iscsuspension-na.com/wp-content/uploads/isc-hp-spread2-lg.jpg)
Basically by threading the bottom portion down you are extending the height of the shock body, thus raising the car. By threading the bottom portion in you are contracting the shock body, thus lowering the car.
eazy (01-23-2012)
#72
big bad bust
The threaded portion of the shock body is anodized and then sprayed with a coating to prevent salt corrosion. So there are some measures in place to prevent the perches from seizing. However, the best way to prevent the perches from seizing is to move them up and down twice a year, once before winter and once after winter.
#74
8) TripAcez- Deposit Pending!
9) Suav7 - Deposit Paid
10) eyeTn3rd - Deposit Paid!
11) bforbrian - Deposit pending
#76
12 pices31
12 pices31
#78
takin care of Business in
Received 4,732 Likes
i might be interested....lemme put my TEIN BASIC on the BM
#79
This is definitely one item I am going to bite the bullet on, even though I have Tein Basics right now, and they are nothing but superb.
#80
Josh....i quick dump question....how much do these weigh in comparison to the Tein ?
I am looking into putting the TL on a little diet and i know this will come in later than sooner....
