Enkei RPF1's
Enkei RPF1's
these are starting to grow on me, i know other azine members have ran them before, but with a high offset. i'm not really a wheel fitment guru, so i'm going to throw out some sizes and you tell me if it will fit or not, what will look best/stance...doesn't matter if i have to roll fenders first time for everything
base tl with no brembos
All 4 corners...don't mind the colors
(18x8.5", 5x114.3, 30mm Offset) Silver
(18x8.5", 5x114.3, 40mm Offset) Silver
(18x9.5", 5x114.3, 15mm Offset) Silver
(17x10", 5x114.3, 18mm Offset) Special Brilliant Coating
(17x9", 5x114.3, 22mm Offset) Silver
(17x9", 5x114.3, 45mm Offset) Silver
(17x9.5", 5x114.3, 18mm Offset) Silver
(17x9.5", 5x114.3, 38mm Offset) Silver
(19x8.5", 5x114.3, 22mm Offset) Silver
Staggered Combo (18x9.5 & 18x10.5 15mm Offset), Matte Black *Limited Edition*
Staggered Combo (18x9,5 & 18x10.5 15mm Offset), Blue *Limited Edition*
pics with any of these sizes will be even better
pros/cons...bitching and moaning lmk
I'm a huge fan of those wheels. I would love a set of those for my TL.
I think the first link posted, 18x8.5 30mm offset, would look best.
Then again the staggered blue 18s would be dope as fuck on a WDP TL. 15mm offset is pretty aggressive though.
I'm running 18x9.5 +15 on my car. Rolled and pulled fenders a bit. But I'm for the flush look, it all depends on what you want. Also, if you want aggressive, you have to run a stiff suspension set up.
how about these two sizes above? not liking the fact that if i roll/pull fenders and use stock wheels later on in the future it will look
17s are going to look too small IMO. The 18s are a good mix of width and offset. badazzTL-S is running 18x9 with a 22 offset and I think they look perfect. Check this thread:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/wdp-tl-s-advan-rss-792035/
You could always get the 18s with the 30 offset and throw some spacers on em.
i was actually looking into these and the varrstoen, if i get this im going for 18x10.5 +15
or 18x9.5 +15 all around, i already got rolled fenders thats no biggie, i duno about the pull!
15 offset is too aggressive for tl fenders it gonna need a roll slight pull, or just camber it. Well that is if your low like me. 30 offset will be fine maybe just roll fenders not too hard. I wouldn't consider pulling unless ur good at it. I agree above that 17 are too small go with 18 x 9 or 18 x 8.5 if you don't want fender work. 35 + offset should clear your stock fenders. Lower than that, your going into fender work( rolling, pulling, etc) Hopes this helps.
Well what do you plan on doing with your car? 15 offset is pretty low for the TL, I would recommend going with an offset 30 or more just to play it safe since you don't want run into fender work. Remember the stock offset for the TL is in the 40s. If I recall, bforbrian had RPF1 with a high offset and they look good on his car, but he also had some beefy tires.
My fenders pulled:
Me pulling my fenders with a fender roller. This is what +15 offset gets...
Examples of what +15 looks like.
My fenders pulled:
1fatcrxnem1
22
06-01-2018 01:23 AM
