Effects of diff size tires on same wheels
Old Jun 11, 2009 | 02:40 PM
scv76_'s Avatar
This is a pretty lame question, but looks wise, what's the difference between the stock 235 tire and say a 245 or 255 tire on the same 8" wheel?
I know the side wall height would be taller, but would the tire bulge out more from the edge of the wheel than the stock tire?
I'm guessing that it won't bulge out any more unless the wheel was narrower?
Old Jun 11, 2009 | 02:49 PM
john_wrap's Avatar
[Mod Censored Title]
as you increase width (e.g. 235 to 245) the tire is obviously going to 'bulge' out a little more. also the side wall doesn't necessarily have to be bigger. simply reduce the side wall ratio (e.g. 45 to 40) to accommodate the increase in width. it's a give and take with the width/side wall relationship (if you want to remain close to stock height that is)
Old Jun 11, 2009 | 06:13 PM
scv76_'s Avatar
I'm okay with the side wall being taller, I was just wondering if the wider tire would result in a larger bulge in an attempt to limit curb rash incidences compared to the stock tire size on the same wheel.
I can live with the speedo and mileage error that will occur
Old Jun 12, 2009 | 06:10 AM
Turbonut's Avatar
Take a look over at the Tire Rack web site. Pick out the size and when the list comes up take hit specs. You'll be able to see the width and height of the various sizes.
http://www.tirerack.com/tires/Spec.j...e1=yes&place=4
Keep in mind, that tread width and other tires dimensions can vary between the brands, even in the same size.
Old Jun 12, 2009 | 01:04 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
And also the wider you go with tires, it will make your rims look smaller as well due to the rubber overhang (bulge).
GhostTL09
Sep 19, 2015 01:57 PM
cammy5
Sep 4, 2015 11:26 PM
nuldabz
Sep 3, 2015 05:49 PM
