EDFC and strut bar
Originally Posted by MaCaY
what if im not gonna install any strut bar???? will i lose a lot??/
tehLEGOman
Received 1,983 Likes
The Greddy 03+ Honda Accord strut bar fits like a glove. If you decide to go with it order some Accord top hats which has the extra stud that is utilized by the bar. All that is needed to do after that is have a hole drilled where the new stud needs to sit. And voila you've got your EDFC compatible strut bar.
TriState ViP Crew
Retired!!! ON TOP!!!
unfortunately... yes... you have to take out the shocks & springs again... then use the spring compressor again to remove the existing top hats and install the Accord top hats... seems like alot of work... but it could be done in a couple of hours...
You could always just use one bolt on the Greedy Strut bar... it's not like you're autocross racing the car everyday to actually feel the difference in the suspension... there's a board member that doesn't have a strut bar installed PERIOD...
OMGWTF4THGENTL
TEIN SS, EDFC, and Greddy bar with TL top hats:
In order to use both mounting points of the bar, drill out the one hole, an replace the TL hats with the Accord hats (The Accord hats have a post that goes through the new hole).
It won;t get any more clear that this.
https://acurazine.com/forums/showthr...ghlight=greddy
lanechanger
10-13-2015 10:56 AM
