EDFC Install
EDFC Install
How much work is it to install the EDFC?
Are there wires you have to run to the coilovers (Tein SS)?
How and where did you put it in the cabin?
OMGWTF4THGENTL
- Yes
- Most folks put the controller in the top CD compartment (cubby)
Ok, nice, but one more question.
For those of you who installed the EDFC, what did you do with the front strut brace. Is there a front strut brace for the non Type-S 5AT TLs?
I heard you have to remove it... what's the deal there?
FOR SALE - BM
yes you either have to remove the strut bar or , modify it... i used the accord top hats and only drilled 1 additional hole in the strut tower, and now i have a greddy strut bar.... fits perfectly
OMGWTF4THGENTL
Well, haven't done it yet, but that's the plan.
1 Post
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
OMGWTF4THGENTL
Originally Posted by shayan
That is what I got done on Friday. I t took my shop 7 hours to complete the install. ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I put my Aspec in 2. I already bought the upper strut compenents so I won;t have to rebuilg the struts... what could take so long?
Remove suspension, drill 2 holes, install suspension...
1 Post
Originally Posted by Kennedy
What was the hold up?
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
TriState ViP Crew
FOR SALE - BM
The greddy bar would still fit if you didn't have the accord top hat, it will just have 1 less bolt on each side... it seemed a little scary to me.. i think that it connects by 2 bolts on each side.. when i did my coilover install i added the top hats, literally 1 drill hole on each side..
OMGWTF4THGENTL
Hey drdamian,
Are you running Thermoblock spacers?
I noticed you had to use spacers to slightly raise the bar. It seems the Greddy bar rides crazy close to the engine cover. Thermoblock spacers actually raise the intake manifold 1/4 in, bringing the manifold in closer contact with the bar... creating that humming/vibration sound.
I'm planning on doing this install soon, and I'm just preparing for what I may need to do to get the Greddy bar in.
FOR SALE - BM
Hey drdamian,
OMGWTF4THGENTL
It's a 1/4 thick plastic gasket that is placed between the intake manifold and the head. It's supposed to isoalte heat from the intake manifold, thus keeping the air cooler as it enters th engine.
But... it raises the instale manifold 1/4".
Can you take a a picture of how close the manifold is to the bar and post it here...?
This is a critical issue that needs to be addressed for folks going this route.
FOR SALE - BM
ok... I will take a few quick flicks tomorrow and post it up... I do not have my intake on the car though, its at a friends house, hes trying to make it out of carbon fiber and is constructing the mold...
tehLEGOman
Received 1,982 Likes
![](http://img144.imageshack.us/img144/48/dsc01810sc2.jpg)
![](http://img244.imageshack.us/img244/1820/dsc01817xv2.jpg)
![](http://img215.imageshack.us/img215/6523/dsc01829nb2.jpg)
![](http://img244.imageshack.us/img244/4134/dsc01821fd5.jpg)
![](http://img144.imageshack.us/img144/8386/dsc01842on5.jpg)
FOR SALE - BM
here are a few pics that i took today.. i hope they help even though i don't have the intake cover on the car.. when i first installed everything i did not have the washers that you can see under the strut bar. I was getting a whining noise when i took my foot off the gas. I think it has to do with the fact that the engine was not able to torque properly. Here are the pics.. The washers are about 2-3mm thick.. The bolt in the pic i think is the main problem that makes the the intake so close.. I have not had any whining issues...
![](http://i45.photobucket.com/albums/f54/dmilillo/Picture318-1.jpg)
![](http://i45.photobucket.com/albums/f54/dmilillo/Picture317.jpg)
![](http://i45.photobucket.com/albums/f54/dmilillo/Picture316-1.jpg)
question: If you want to adjust dampening or height on tein ss (no edfc), do you have to remove the factory strut bar? If yes, then which strut bar applies force closest to stock that allows adjustment? (in order to keep from increasing understeer, and to not risk a cracked windsheild)
FOR SALE - BM
In order to adjust the height you will need to take the tires off and turn the perch stops. The edfc only controls the dampers. Without it you will have to go under the hood and just turn the screws on the top of the coilovers. To adjust the back you will have to remove the backseat. The only reason I got the edfc was bc I didn't want to take the backseat apart everytime I wanted to make adjustments. Imo for our cars, its worthless to get the ss's and not have an edfc. I can adjust on the fly any time I please
TL on 20's
Originally Posted by HQTL6SPD
so if i were to have acess to a lift, would i need to take the tires off then?
FOR SALE - BM
yeah, a lift would definetely be easier bc to raise and lower the car there are 2 screws that turn against each other and they are the stops for the springs.. there are no marking or specific stops, so your probably gonna have to use a tape measure.. i got my coilovers from another member on the site. They were already set up so all i did was install them..
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
