EDFC Help!
Old Dec 23, 2010 | 01:27 PM
akrapovic's Avatar
08 WDP ASPEC TLS 6SPD MT
EDFC Help!
Hey im doing my install on my edfc and i am pretty much done but i still cant find anywhere to run the wires from the engine bay to the inside of my car. I already wired and tested everything and works greats, but the last thing i need to do is connect the front wires to the edfc mounted in my center console. Any help would be great. My last option is to drill a small hole through my firewall to run the wires to the inside.
Old Dec 23, 2010 | 02:23 PM
apnorm's Avatar
I thought I read that there was already a hole in the middle of the firewall that you'd be able to use. I believe I read it in a thread that talked about relocating the battery to the trunk.
Old Dec 23, 2010 | 02:42 PM
AMUA6's Avatar
ScoobyZINE
Originally Posted by apnorm
i thought i read that there was already a hole in the middle of the firewall that you'd be able to use. I believe i read it in a thread that talked about relocating the battery to the trunk.
+1
Old Dec 23, 2010 | 03:13 PM
akrapovic's Avatar
I'll check it out again and see if I can find it.
Old Dec 26, 2010 | 07:21 PM
akrapovic's Avatar
not many replys on this subject
Old Dec 27, 2010 | 11:33 AM
BoxOn20s's Avatar
There is a rubber grommet near the brake master cylinder where the rest of the engine harness passes through the firewall. Make a small slit in the rubber between the harness and edge of the grommet. Make sure its small but large enough to get each connector through individually. A little sealant after passing the motor harness wouldnt be a bad idea. Hope this helps.
Old Dec 27, 2010 | 12:42 PM
akrapovic's Avatar
Where does it come out inside of the car? Like a general area
Old Dec 28, 2010 | 06:33 PM
BoxOn20s's Avatar
If I remember correctly, it comes out above the dead pedal, pretty close to the height of where the steering column passes through the fire wall. You wont see it until you remove the black plastic trim under the dash. Ive installed 2 EDFC now using that same location. Its also the same grommet I use to pass my amplifier's power wire through.
Old Dec 28, 2010 | 07:41 PM
akrapovic's Avatar
Awesome thx
Old Dec 29, 2010 | 03:46 PM
akrapovic's Avatar
my car is a 6spd btw is it the same? because it looked like a clutch master cyclinder was where you were talking about. i could be wrong tho
Old Dec 29, 2010 | 06:29 PM
BoxOn20s's Avatar
You're in the right area. Just follow the engine compartment harness. That grommet should be in the same location regardless of the transmission. It just might be a little harder to get to since you have a 6mt. Or you can remove the lower plastic cover above the pedals to see the harness and grommet I am talking about.
Old Dec 30, 2010 | 11:21 AM
akrapovic's Avatar
so i said fuk it got my unibit and drilled a small hole behind the glovebox. It was alot easier and i barely had to take anything apart. Took me a total of 10mins to drill the hole run the wires and have everything hooked up. Thanks for the help everyone, mod you can close this thread
thanks.
BoricuaTL
Apr 8, 2016 01:08 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sponsored Sales & Group Buys
694
Apr 27, 2010 02:02 AM
Michael03TLS
Apr 14, 2006 05:24 PM
Qwerty96
Oct 4, 2005 01:57 AM
