EAR wheels sr01
EAR wheels sr01
Just picked up a set of ear sr01. The fronts are 9.5 +22 and rear is 10in +22. The rear fits perfect. However the front will not clear the brakes I have Brembos please help and what I need to do?
If the front cant clear the Brembo pads you need spacers. Id say 10mm spacers would probably be fine. Might be over kill.
If you can measure how or tell how much space you need you can go with a spacer that big. 5mm might work. 10mm would be closer to half an inch which would give the front near the same clearance as as the rear.
