Dubs??
Old Jun 11, 2002 | 10:58 AM
MahaRaja's Avatar
Dubs??
Would 20x8 or 20x8.5 fit on a lowered 1999 3.2TL, which is lowered by the eibach prokit???
Old Jun 11, 2002 | 11:47 AM
StanMan's Avatar
if you get a high enough offset it should fit, but then it's probably pretty wide, so you would rub some. the smallest tire is 245/40 i believe and that is bigger than the stock rolling diameter. you would be *sacrificing* a small amount (inaccurate speedo, rubbing) if you went with these wheels.
Old Jun 11, 2002 | 01:17 PM
noleaf74's Avatar
I believe the CL w/ the 20" lorinsers has a 245/35/20 inch tire so that would be the best choice of tire for dubz, but the offset is gonna have to be pretty high as StanMan said, probably around +50 for 20x8 and maybe like a + 55 or so for 20x8.5
Old Jun 11, 2002 | 11:33 PM
Lawaia's Avatar
Moderator Alumnus
245/35-20 is the smallest 20" tire made (for now)...a whopping +1" taller in height (diameter). I would have to guess that this would also affect acceleration and performance due to the larger rotating mass.
Old Jun 14, 2002 | 02:33 PM
Blazin TL's Avatar
GO SEMINOLES!!!
so for wheels 8 inches wide you need a 50+ offset?
Sep 14, 2015 03:16 PM
kansaiwalker1
Nov 6, 2004 04:02 PM
brety
Jul 13, 2004 01:26 AM
gavriil
Jan 4, 2004 12:19 PM
kansaiwalker1
Nov 15, 2003 05:52 AM
