does sway bar make it possible?
I decided to buy 05TL 5AT w/navi over 04'G35 within a few days. I test-drove TL yesterday. Everything was great except handling. The handling of the TL was too soft, undulate, rolling and floaty in corners, even in chainging lanes.
I have read many threads about Comptech sway bar. but I just want to make sure a few things....
1.Can installed swaybar make 5AT TL comparable (or close) to G35 in handling?
2.After sway-bar installed, does it affect TL's warranty?
3.Does it need a regular maintanence for the sway bar?
4.can i just install sway bar only or should it be installed with spring or some other things??
2)no
3)none
4)Install A-spec suspension for an awesome ride in addition to the sway bar and you will be extremely happy. Blows away the G35. About $1k for the suspension, installation and alignment = Money well spent
do you need a wheel alignment if you put on just the sway bar?
Originally Posted by New2004AcuraTLman
1)Yes
2)no
3)none
2)no
3)none
Uh, you do realize that this thread is almost two years old?
But it's all good. The A-Spec suspension and the Comptech RSB are the two best and most functional mods you can make on the 3G TL.
Originally Posted by JJaber06
Isn't the A-spec suspension just better coilovers? For that price, wouldn't it be better to get the Tien SS?
Ride quality doesn't really matter to me as long as it sticks to the road and nails turns....Is the A-spec suspension really better than the SS?
a-spec gives you all the pros of suspension, with none of the negatives. your only complaint may be that it is not low enough.
keep in mind, a low tien setup will require a camber kit, which costs $$$.
With the A-Spec on my 3G TL, it mostly removes the dive and squat on acceleration and deceleration, and there is less body roll, but not nearly as much as I recall from my 2g TL. It lowers the car 1/2-1 inch (mine was 1/2 inch) and the ride quality was still compliant. It made the steering more precise and with the Comptech RSB, it did ride like it was on rails. The best part is that dealers will install it and warranty it.
So again, what suspension setup you get depends on what you want out of your suspension.
DiZ, a camber kit controls the amount the wheels are tilted in or out relatively to the body of the car.
exactly......and with our TLs you cant adjust camber. So if you lower your car with springs or whatever, your camber will begin to go more negative, meaning that the top of your wheels will lean in more when looking at them from the back.
but in some cases you wont need a camber kit, it all really depends if and how much your camber is really out.
marcelft
07-10-2018 07:17 PM
MonkeyTrucker
09-21-2015 07:15 PM
k6biv
09-10-2015 07:37 PM
