do i need a camber kit
Old 05-03-2010, 10:22 PM
a06tl's Avatar
i have a 2006 tl base with auto. if i go with the tien s springs and the blue tokicko shocks, will i need a camber kit. i still have the stock wheels, but i plan on getting 18" staggered in the near future. what width wheels and offset should i get and tire size to ease the burden from rubbing. any help will be greatly appreciated.
Old 05-07-2010, 03:36 PM
socal WDP
diskinnect's Avatar
if you want to run staggered 18's i would suggest you get a both front and back camber kits because you wont be able to rotate your tires. your drop wont increase your camber by that much but the fact that you cant rotate your tires will really kill your front ones more frequently. with the drop your camber will be in factor spec which is around 1.2 degrees (which will still wear your tires out faster) and your rears will be around 2 degrees which i suggest you get a rear camber kit regardless. just make sure you also get a very good alginment and make sure the toe is set to zero. because toe is the biggest killer of tires
Old 05-07-2010, 03:41 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
With those springs, you don't NEED a camber kit, but it wouldn't hurt. A good alignment will be fine with that drop.
Old 05-07-2010, 03:54 PM
1st TL-S on air in
wrxyboy's Avatar
^^ +1 the springs wont throw the alignment out to much but it is still good to get one to make sure everything is in check. I get my alignment checked every 3 months but that is due to the suspension i am on.
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
Jinkazetsukai
11-21-2015 05:28 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: do i need a camber kit
