Damn Pothole
Damn Pothole
I was driving today to work, going 45-50 mph. suddently i hit a pothole on the front right sides. It was hard! and sounded really loud. I checked the tire monitor and it was ok.
Later after work my tire were flat....
Is there a chance to repair? or is it completely ruined?
If I have to change should i change all 4?
I havent change the tires since i got the car... now the car has 51k...
The last time the service guy told me that it would last me 15-20k more....
Im thinking of getting a dunlop SP sport signature, at discount tire.
would it be ok getting 245 instead of 235?
Im also worry that something else got damage...
what should I asked them to check?
Thank you!
Thank you!
Check your alignment and consider yourself lucky. I hit a pothole on lake shore drive in Chicago and my side curtain airbag and seat airbag deployed! $2700 later it was fixed but they screwed up my hands free link during the repair... HFL is booting up...HFL is booting up. Depressing
if you hit a pothole that hard you most likely put a bend in your rims and a bubble in your tire.....
Thank you!
Thank you!
However if you hit a pothole hard enough to break the bead/seal, it's very possible that you damaged the tire and put a bubble in it (rubber layers seperated). IF that happens then you need to replace the tire as it's unsafe to drive on.
My suggestion is to put on your spare and go to discount tire or your tire shop you have been dealing with before. Tell them what happened and tell them from the get-go that your budget is pretty tight. For example, a buddy of mine who has dealt with Discount tire for the past 8-10 sets of tires (at great prices I might add, 10 dollars more than tirerack for each tire) hit a pothole and put a bubble in his tire but didn't bend the rim. His tires were at 4/32nds and he didn't have road hazard. He told them his budget was a bit tight and basically they ended up pro-rating all 4 tires and bought him 1 front tire, he paid for 3 tires minus the pro-ration. A set of tires that should have cost him close to 1000 dollars cost him around 500.
My feeling is that you probably bent the wheel or broke the tire seal like csmeance said. Take it to the tire shop. It is possible that you did more damage but start with the tire and then keep an eye on the suspension.
Sometimes they will also do a free alignment at the tireshop for you. See if you can get that done.
Good luck. My wife hit a pothole in NYC and took out a 2 tires and wheels on my old Infiniti.
Get your wheel/tire to the shop and have them check it. Tire could be damaged or rim can be bent, or both. Also get your alignment checked - this should tell you if you did any other suspension damage.
My GF hit a pothole on a poorly maintained road in Seattle last March and it left her on the side of the road in my TL. It completely bent the inside lip of the rim causing instant flat. Surprisingly, the tire was salvageable. I had to order a new replacement wheel on tirerack, pay to have it sandblasted, and powder coated to match my other 3 powder coated rims. Grand total was $400 + alignment.
I filled out a Tort claim form along with the repair invoices to the city detailing the incident. After sending it to the wrong city/county ordinance a few times (WSDOT, King County), I finally got my form directed to the right place (City of Seattle). Needless to say, they paid my $400 bill just like that with a check in the mail. ; )
I recommend looking into getting city to pay for that damage if you want to spend some time filling out the forms.
In the end i got the goodyear eagle gt...
what i can tell from my new tire... is that is smooth and has better traction....
the only con is that the road noise is a bit louder than than mich
