Cross Drilled and slotted or Slotted which is better?
sonny@tirerack (12-30-2013)
Received 3,824 Likes
Slotted
slotted, i mean slotted and drilled look cooler in my opinion but you are taking the structural safety away from the rotor. Now you probably aren't driving hard enough to make that much of a difference but i guess the thought of that is scary.
Neither. Your Acura TL will not benefit from either for everyday street driving. Plus all the issues that people mention with warping and cracking, just get OEM rotors or a quality aftermarket one. Plus IMO they would look out of place on a TL. You expect to see things like that on a Nissan GTR or a Corvette Z06, but not a family sedan. Sorry I'm being the mid grinch again lol
Flame away.
Flame away.
Acura-OC (12-29-2013)
I agree. I have had my share of TL's and surprisingly the OEM rotors are very good IMO. I have never had one of my TL's develop warped rotors. I did buy a used Type s that came from the previous owner with drilled and slotted rotors that were junk. Bad warpage I junked them and went with stock Type s rotors and pads and the brakes are excellent.
Nothing wrong with the OEM rotors at all. I like the look of slotted rotors, so that's what I have. Purely for aesthetic reasons. I guess they cool quicker and disperse the heat better then blank ones, but for daily street driving I cant imagine they offer much of an advantage, if any.
I've posted objective data on blank vs slotted vs drilled but I'm not going to type it up again.
I would never run drilled (again) on a street car and they can be a safety liability on a race car.
Slotted has no disadvantage but may not have any advantages vs blank depending on the pads. I went with slotted on my Stoptech BBK because it was the same price as blank and there's the chance it may improve performance by reducing the chances of pad glazing. Plus these rotors do not have as many slots or crazy patterns as some do. Behind the stock rims you really don't see the slots. Going off topic, I also got the black calipers so unless you own a TL and know it well you're not going to know it has aftermarket brakes. Behind the stock 17s you can tell they're larger than the Brembos but you don't see the slots and most importantly no one outside of the TL world is going to know.
One thing not mentioned in the OP was the definition of "better". Are we talking about resistance to fade, consistency over a large range of temps, regular driving through deep puddles/lots of standing water?
nttstt444 (12-28-2013)
Slot Machine Lubricator
I bought mine knowing they have no real benefit for daily driving. To me it's purely aesthetic. I like the way the look.
Attachment 108361
Attachment 108361
Undying Dreams (12-30-2013)
I'm assuming those are carbon ceramic disks which will glow at a lower temp than steel. They can get away with "drilling" because they're thermally neutral. No expanding or contracting.
I personally would trust drilled steel rotors less at high temps. They don't help cooling except under conditions a TL is never going to meet.
I can understand wanting your brakes to look nice but crossdrilled rotors will crack. Everyone of them if given enough time. My 13" Rotoras cracked do bad they could be felt through the pedal. No thanks.
Acura_Dude (12-29-2013)
Just get a centric rotor, they are cheaper than oem and yet the quality isn't far if not better than oem one.
I read dozens of related threads and the blank Brembo seemed to be closest to an OEM rotor, so I chose that. Rear is $34 at Rock Auto. Interestingly, there isn't a Brembo front rotor.
nttstt444 (12-29-2013)
Received 6,470 Likes
Cool shots.....
lots of misinformation in this thread, this is the real deal:
1. Slotted &/or Drilled rotors reduce the weight of the rotors, thus less sprung mass which means a faster car.
2. Drilled rotors mean less metal and surface area compared to slotted so they cool and heat up faster compared to a slotted, and those heat up/cool faster than the OEM to an extent depending on design (somewhat good for tracks, bad for the street sometimes)
3. Slotted rotors give more "bite" to the brakes as the slots cut into the pad during breaking. However this reduces pad life significantly. I would not advise slotted rears.
4. Most "Drilled" rotors are literally drilled stock rotors which are BAD!!!! These creates stress fractures that can cause the rotor to fail with continued heat cycles causing a crack at the holes. The way to avoid this is to cast the disk with the holes in it first and then to refine them. Racing Brake has a revolutionary idea where they put holes in the slots of the rotors instead!
5. Inner vane design is VERY important to cooling. Most aftermarket brakes don't use any upgraded design to allow for better cooling. Some do, for example Racing Brake designs the inner portion of rotors to have better air flow and to pump more air into the rotor to cool it faster.
6. 2pc rotors are expensive upfront but can be cheaper in the long run. They tend to be lighter than 1pc rotors and you only have to replace the wearable part. For most people this isn't needed and is overkill!!!!!
7. Don't cheap out on your brakes, even the "brembo" blanks can be crappy. I'd recommend a good brand with tested, tried and true results. I have put 120+K miles on my Racing Brake Rotors and they still perform amazingly well.
nttstt444 (12-30-2013)
The only area drilled makes a clear difference is when the brakes get wet and at elevated temperatures they can give a more consistent pedal feel. Also at elevated temps they can cause excessive pad wear.
I got tired of all of the myths and misinformation and started collecting my own information on my own brakes and purchased a few SAE white papers on the subject.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
09-25-2015 06:14 PM
