Couple of questions
Old Sep 5, 2005 | 12:36 AM
KrazyEd's Avatar
Couple of questions
Ok...I am going to be getting my TL in a about a month and I am just trying to decide on what rims to get. However, I have a couple of questions
If i get a rim that is 19x8.0 and tires at 235/35/19, should i got with a +40 offset or a +49 offset? I plan on getting the Aspec suspension and I do not want to rub and i really dont want to cut anything. I did some searching and saw what people had but no one seemed to have this combo
Old Sep 5, 2005 | 12:16 PM
PoochaKannInc's Avatar
Shift_faster
40 mm offset should be ok. The stock offset is 45mm. I'm currently running 35mm wheels with the A-Spec suspension and there is no rubbing.
The 49mm offset is way too high. That will not fit (I don't think). Just make sure that the spoke design will clear the front brakes (if you have a 6mt). Other than that I think you should be fine.
If you are still not sure, call up the wheel manufacturer and get their professional opinion.
Old Sep 6, 2005 | 07:02 PM
KrazyEd's Avatar
what about if the rim is 19 x 8.5?
booma1218
May 3, 2016 07:39 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
njresendez
Sep 24, 2015 11:41 PM
datadr
Sep 12, 2015 09:12 PM
MyGuti
Sep 12, 2015 06:52 PM
