Control Arms/Sway Bar End Links
Old 05-26-2016, 11:18 PM
5th Gear
KBP07's Avatar
Does anyone know if the 2007 TL Type S and the Base TL share the same parts for the front lower control arms and sway bar end links?
I ordered LCAs and all 4 end links, and brought it to the shop today.
They called me a couple hours saying something about the bolt holes not being the right size and needing to use a washer to keep the links tight. Also said that they may have sent me the arms and end links for a base TL and not the Type S.
From checking oemacuraparts.com it seems like they have the same part numbers...
Old 05-27-2016, 06:47 AM
Turbonut's Avatar
I agree:
LCA/Bushings same '07-'08 TL/TLS
Bolts the same '04-'08 all
Front end links same '07-'08 TL/TLS
Rear end links same '04-'08 all
What are the part numbers you received?
As you have found, you can verify on the same site I use:
Acura Parts | OEM Acura Parts | Factory Acura Parts
Old 06-28-2016, 01:38 AM
h1708926's Avatar
Hello everyone.
I bought front end links. and they are different size, Axis of left side is 5cm and of right side is 4cm. is this right? or a seller gave me a wrong part?
Old 06-28-2016, 06:38 AM
Turbonut's Avatar
Originally Posted by h1708926
Hello everyone.
Left/right end links are different.
Old 03-25-2017, 01:03 AM
Chad05TL's Avatar
i never heard that each side was different.
But I think the hole sizes vary from going from a 2004/6 to 2007/8.
And I heard some people just drilled out the connection on the lower control arm and used the larger links for the 07/08 base or Type-S
Like how much bigger is it going from a 2005 to 07/08?
1080p
05-02-2016 07:00 PM
Quick Reply: Control Arms/Sway Bar End Links
